X-Street STR Viper Wheel Replacement
    1. X-Street STR Viper Wheel Replacement, Wheel: step 1, image 1 of 2 X-Street STR Viper Wheel Replacement, Wheel: step 1, image 2 of 2
      • Remove the wheel. Begin by grabbing your metal spudger or a guitar pick to pop off the plastic cap in the middle of the wheel.
      • Use the #2 Phillips screwdriver to remove the 4mm Phillips #2 screw inside the wheel.
      • From here you should be able to easily pull off the wheel from the car and you're finished!
      Ask FixBot
Ian Johnson
357 Reputation
2 Guides authored
Cal Poly, Team 12-6, Lancaster Spring 2015 Member of Cal Poly, Team 12-6, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G6
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 31
All Time: 630
