X-Street STR Viper Remote Control Motherboard Replacement
    1. X-Street STR Viper Remote Control Motherboard Replacement, Remote Control Motherboard: step 1, image 1 of 1
      • Turn off the remote control. Flip power switch to the off position.
      • Remove the battery from bottom of the remote control for further safety measures.
      Ask FixBot
    2. X-Street STR Viper Remote Control Motherboard Replacement: step 2, image 1 of 1
      • Remove all seven 3mm Phillips #2 screws from the underside panel.
      Ask FixBot
    3. X-Street STR Viper Remote Control Motherboard Replacement: step 3, image 1 of 1
      • Remove five 3mm Phillips #2 screws that connect the motherboard to the back outer shell.
      Ask FixBot
    4. X-Street STR Viper Remote Control Motherboard Replacement: step 4, image 1 of 1
      • Detach the motherboard. Use soldering tools to desolder the red and black wires from the motherboard. To do this, refer to the how to solder/desolder page.
      Ask FixBot
    5. X-Street STR Viper Remote Control Motherboard Replacement: step 5, image 1 of 1
      • Replace the motherboard. Solder the wires back on to the new motherboard using the soldering kit. The black wire should be on the left and the red wire should be on the right.
      Ask FixBot
Cate Kraska
144 Reputation
1 Guide authored
Cal Poly, Team 12-6, Lancaster Spring 2015 Member of Cal Poly, Team 12-6, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G6
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 37
All Time: 1,126
