Wyze Cam V2 Microphone Replacement
  1. Wyze Cam V2 Microphone Replacement, Back Panel: step 1, image 1 of 1
    • Open up the camera stand to expose the bottom plate of the camera.
    • Remove two 4 mm silver screws using the Phillips #0 screwdriver.
    Ask FixBot
  2. Wyze Cam V2 Microphone Replacement: step 2, image 1 of 1
    • Using the iFixit opening tool, carefully pry open the bottom plate to gain access to the camera's internals.
    Ask FixBot
  3. Wyze Cam V2 Microphone Replacement: step 3, image 1 of 2 Wyze Cam V2 Microphone Replacement: step 3, image 2 of 2
    • Open up the back panel using the iFixit opening tool and unclip the panel from the rest of the device.
    • Be careful of the charging port while taking it off.
    Ask FixBot
  4. Wyze Cam V2 Microphone Replacement: step 4, image 1 of 2 Wyze Cam V2 Microphone Replacement: step 4, image 2 of 2
    Tool used on this step:
    $3.99
    Buy
    Ask FixBot
  5. Wyze Cam V2 Microphone Replacement, Motherboard: step 5, image 1 of 1
    • Remove the single 6 mm screw located deep inside the device using a Phillips #000 screwdriver.
    • Carefully remove the motherboard from the device.
    Ask FixBot
  6. Wyze Cam V2 Microphone Replacement: step 6, image 1 of 1
    • Remove the remaining two 6 mm screws from the motherboard with a Phillips #0 screwdriver.
    Ask FixBot
  7. Wyze Cam V2 Microphone Replacement: step 7, image 1 of 1
    Buy
    • Using the precision tweezers, detach the charging port’s motherboard from the camera’s motherboard.
    Ask FixBot
  8. Wyze Cam V2 Microphone Replacement, Microphone: step 8, image 1 of 1
    • On the camera's motherboard locate the microphone labeled "MIC1".
    Ask FixBot
  9. Wyze Cam V2 Microphone Replacement: step 9, image 1 of 1
    • Desolder the iron piece holding down the microphone to the motherboard.
    Ask FixBot
  10. Wyze Cam V2 Microphone Replacement: step 10, image 1 of 1
    • Carefully detach the microphone from the motherboard.
    Ask FixBot
Oluajo
243 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 48
All Time: 581
