WowWee Miposaur Battery Replacement
    1. WowWee Miposaur Battery Replacement, Battery: step 1, image 1 of 1
      • Use a Phillips head #1 screwdriver to remove 3 2mm screws from MiPosaur's underside panel.
      • You may need to use an extension on your screwdriver to work around small space between the panel and the dinosaur's leg.
      • You can remove the bottom screw completely, but the top two screws are captive and do not need to be removed entirely.
      Ask FixBot
    2. WowWee Miposaur Battery Replacement: step 2, image 1 of 1
      • Firmly grasp the panel and pull apart from the base of the toy.
      Ask FixBot
    3. WowWee Miposaur Battery Replacement: step 3, image 1 of 1
      • Remove the battery from the device.
      Ask FixBot
Melissa Bender
97 Reputation
1 Guide authored
iFixit, Team S1-G1, Weber Summer 2018 Member of iFixit, Team S1-G1, Weber Summer 2018
FIX-WEBER-SU18S1G1
5 Members
395 Guides authored
1 Guide Comment
Moving the MiPosaur along the ground will give it a burst of power, and so can create an electrical hazard when touching internal parts. If you keep moving it, the low battery sequence will commence and it will power off, even if the power switch is set to off. If you want to do this, drive it in fast circles.
Michael Deitz - Reply Share
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 46
All Time: 1,606
