WowWee MiP Robot Tire Replacement
Views: 7K
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
97
All Time:
6,988
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide is designed to help users remove MiP’s wheels. MiP has two wheels that are connected to its body with screws. If the wheels need replacement or cleaning, follow this guide.
Tools
    1. WowWee MiP Robot Tire Replacement, Wheel: step 1, image 1 of 2 WowWee MiP Robot Tire Replacement, Wheel: step 1, image 2 of 2
      • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
      • This plastic material is not replaceable. Any damage will be noticeable.
      Ask FixBot
    2. WowWee MiP Robot Tire Replacement: step 2, image 1 of 2 WowWee MiP Robot Tire Replacement: step 2, image 2 of 2
      • Remove the 12.0 mm Phillips #2 screw.
      • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
      Ask FixBot
    3. WowWee MiP Robot Tire Replacement: step 3, image 1 of 1
      • Pull the wheel off of the square axle.
      • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
      Ask FixBot
    1. WowWee MiP Robot Tire Replacement, Tires: step 4, image 1 of 2 WowWee MiP Robot Tire Replacement, Tires: step 4, image 2 of 2
      • Remove the three 7.7 mm Phillips #1 screws.
      Ask FixBot
    2. WowWee MiP Robot Tire Replacement: step 5, image 1 of 3 WowWee MiP Robot Tire Replacement: step 5, image 2 of 3 WowWee MiP Robot Tire Replacement: step 5, image 3 of 3
      • Separate the rubber tire from the rim.
      • Push the collar out to separate the plastic layers of the wheel.
      • When reassembling, align the groove and the key of the two wheels' halves together.
      Ask FixBot
5 other people completed this guide.
Moira Keahon
257 Reputation
3 Guides authored
1 Guide Comment
my MiP has plastic over his wheels
Clarrie O'HARE - Reply Share
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 97
All Time: 6,988
