WowWee MiP Robot LED Light Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
102
All Time:
1,249
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The LED light on the MiP indicates what mode the robot is in. If this light is malfunctioning, using the MiP is difficult.
Tools
    1. WowWee MiP Robot LED Light Replacement, Battery: step 1, image 1 of 2 WowWee MiP Robot LED Light Replacement, Battery: step 1, image 2 of 2
      • Remove the three 12.0 mm Phillips # 2 screws from the battery cover.
      Ask FixBot
    2. WowWee MiP Robot LED Light Replacement: step 2, image 1 of 2 WowWee MiP Robot LED Light Replacement: step 2, image 2 of 2
      • Carefully pull the battery pack from the robot.
      • Remove the batteries from the battery pack.
      Ask FixBot
    1. WowWee MiP Robot LED Light Replacement, Wheel: step 3, image 1 of 2 WowWee MiP Robot LED Light Replacement, Wheel: step 3, image 2 of 2
      • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
      • This plastic material is not replaceable. Any damage will be noticeable.
      Ask FixBot
    2. WowWee MiP Robot LED Light Replacement: step 4, image 1 of 2 WowWee MiP Robot LED Light Replacement: step 4, image 2 of 2
      • Remove the 12.0 mm Phillips #2 screw.
      • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
      Ask FixBot
    3. WowWee MiP Robot LED Light Replacement: step 5, image 1 of 1
      • Pull the wheel off of the square axle.
      • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
      Ask FixBot
    1. WowWee MiP Robot LED Light Replacement, WowWee MiP Robot Body Disassembly: step 6, image 1 of 2 WowWee MiP Robot LED Light Replacement, WowWee MiP Robot Body Disassembly: step 6, image 2 of 2
      • Remove the eight 9.3 mm Phillips #1 screws from the back of the robot.
      Ask FixBot
    2. WowWee MiP Robot LED Light Replacement: step 7, image 1 of 3 WowWee MiP Robot LED Light Replacement: step 7, image 2 of 3 WowWee MiP Robot LED Light Replacement: step 7, image 3 of 3
      • Remove the arms from the body.
      • Carefully open the body compartment.
      • Open the compartment slowly. There are wires connecting the two body pieces together. If pulled too hard, the wires and/or the motherboard could be damaged.
      Ask FixBot
    3. WowWee MiP Robot LED Light Replacement: step 8, image 1 of 1
      Tool used on this step:
      Buy
      • Using precision tweezers, disconnect the following three bundles of wires:
      • Connecting the battery pack to the motherboard.
      • Connecting the power switch to the motherboard.
      • Connecting the speaker to the motherboard.
      Ask FixBot
    1. WowWee MiP Robot LED Light Replacement, LED Light: step 9, image 1 of 2 WowWee MiP Robot LED Light Replacement, LED Light: step 9, image 2 of 2
      • Remove the four 7.5mm Phillips #1 screws.
      Ask FixBot
    2. WowWee MiP Robot LED Light Replacement: step 10, image 1 of 2 WowWee MiP Robot LED Light Replacement: step 10, image 2 of 2
      • Carefully pull the motor and motherboard assembly straight out from the base.
      • Be careful not to break the plastic rods that go through the motor assembly and are connect to the shell.
      Ask FixBot
    3. WowWee MiP Robot LED Light Replacement: step 11, image 1 of 1
      Buy
      • Use the precision tweezers to unplug the bundle of wires.
      Ask FixBot
    4. WowWee MiP Robot LED Light Replacement: step 12, image 1 of 1
      • Slide the head back to separate it from the body.
      • The motherboard does not need to be separated from the head to replace the LED light.
      Ask FixBot
    5. WowWee MiP Robot LED Light Replacement: step 13, image 1 of 1
      • Remove the 7.5mm Phillips #1 screw.
      • The LED light is soldered to the small circuit board.
      Ask FixBot
Courtney
236 Reputation
1 Guide authored
USF Tampa, Team 3-4, Wollert Spring 2016 Member of USF Tampa, Team 3-4, Wollert Spring 2016
USFT-WOLLERT-S16S3G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 102
All Time: 1,249
