WowWee MiP Robot Speaker Replacement
Views: 1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
109
All Time:
1,048
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The MiP communicates with playful sounds. A malfunctioning speaker will greatly diminish the user experience. Use this guide to replace the speaker in your WowWee MiP robot.
Tools
    1. WowWee MiP Robot  Speaker Replacement, Battery: step 1, image 1 of 2 WowWee MiP Robot  Speaker Replacement, Battery: step 1, image 2 of 2
      • Remove the three 12.0 mm Phillips # 2 screws from the battery cover.
      Ask FixBot
    2. WowWee MiP Robot  Speaker Replacement: step 2, image 1 of 2 WowWee MiP Robot  Speaker Replacement: step 2, image 2 of 2
      • Carefully pull the battery pack from the robot.
      • Remove the batteries from the battery pack.
      Ask FixBot
    1. WowWee MiP Robot  Speaker Replacement, Wheel: step 3, image 1 of 2 WowWee MiP Robot  Speaker Replacement, Wheel: step 3, image 2 of 2
      • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
      • This plastic material is not replaceable. Any damage will be noticeable.
      Ask FixBot
    2. WowWee MiP Robot  Speaker Replacement: step 4, image 1 of 2 WowWee MiP Robot  Speaker Replacement: step 4, image 2 of 2
      • Remove the 12.0 mm Phillips #2 screw.
      • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
      Ask FixBot
    3. WowWee MiP Robot  Speaker Replacement: step 5, image 1 of 1
      • Pull the wheel off of the square axle.
      • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
      Ask FixBot
    1. WowWee MiP Robot  Speaker Replacement, WowWee MiP Robot Body Disassembly: step 6, image 1 of 2 WowWee MiP Robot  Speaker Replacement, WowWee MiP Robot Body Disassembly: step 6, image 2 of 2
      • Remove the eight 9.3 mm Phillips #1 screws from the back of the robot.
      Ask FixBot
    2. WowWee MiP Robot  Speaker Replacement: step 7, image 1 of 3 WowWee MiP Robot  Speaker Replacement: step 7, image 2 of 3 WowWee MiP Robot  Speaker Replacement: step 7, image 3 of 3
      • Remove the arms from the body.
      • Carefully open the body compartment.
      • Open the compartment slowly. There are wires connecting the two body pieces together. If pulled too hard, the wires and/or the motherboard could be damaged.
      Ask FixBot
    3. WowWee MiP Robot  Speaker Replacement: step 8, image 1 of 1
      Tool used on this step:
      Buy
      • Using precision tweezers, disconnect the following three bundles of wires:
      • Connecting the battery pack to the motherboard.
      • Connecting the power switch to the motherboard.
      • Connecting the speaker to the motherboard.
      Ask FixBot
    1. WowWee MiP Robot  Speaker Replacement, Speaker: step 9, image 1 of 2 WowWee MiP Robot  Speaker Replacement, Speaker: step 9, image 2 of 2
      • Remove the two 7.5 mm Phillips #1 screws holding the speaker bracket in place.
      Ask FixBot
    2. WowWee MiP Robot  Speaker Replacement: step 10, image 1 of 1
      • Remove the plastic bracket covering the speaker.
      Ask FixBot
    3. WowWee MiP Robot  Speaker Replacement: step 11, image 1 of 1
      • Gently remove the speaker from the MiP.
      • During reassembly, be sure to place the speaker in the same position.
      Ask FixBot
Daniel Burkholder
623 Reputation
4 Guides authored
USF Tampa, Team 3-4, Wollert Spring 2016 Member of USF Tampa, Team 3-4, Wollert Spring 2016
USFT-WOLLERT-S16S3G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 109
All Time: 1,048
