WowWee CHiP Robot Dog Battery Replacement
  1. WowWee CHiP Robot Dog Battery Replacement, Battery: step 1, image 1 of 1
    • Place CHiP on its back so that its stomach is facing you.
    Ask FixBot
  2. WowWee CHiP Robot Dog Battery Replacement: step 2, image 1 of 2 WowWee CHiP Robot Dog Battery Replacement: step 2, image 2 of 2
    • There are three small hex screws connecting the battery to CHiP. Remove all screws with a hex screwdriver and remove battery casing.
    Ask FixBot
  3. WowWee CHiP Robot Dog Battery Replacement: step 3, image 1 of 2 WowWee CHiP Robot Dog Battery Replacement: step 3, image 2 of 2
    • Once the top face of the battery is off, you will see a small rectangular box that the batteries are inside. There are 4 Phillips head screws in the box. Remove all screws with a Phillips head screwdriver.
    Ask FixBot
  4. WowWee CHiP Robot Dog Battery Replacement: step 4, image 1 of 3 WowWee CHiP Robot Dog Battery Replacement: step 4, image 2 of 3 WowWee CHiP Robot Dog Battery Replacement: step 4, image 3 of 3
    • Once the battery is removed from body, the battery should be connected by a red and black wire. There is a red rectangular connector that easily pulls apart. Pull apart the red rectangular connector.
    Ask FixBot
4 other people completed this guide.
9 Guide Comments
Where do I get a battery
cajuin6736 - Reply Share
If you find a source please let me know. Thanks
Need Help - Reply Share
Heres a replacement. Be sure to order the correct plug at the auction (C plug) https://rover.ebay.com/rover/0/0/0?mpre=...
Did you find the battery?
aura - Reply Share
those batteries
are for the copter not the dog. I need the dog battery the Chip dog needs two 18650 lithium ion batteries my battery shop could get the individual batteries but could not work on the lithium as to volatile.
v scigliano - Reply Share
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 105
All Time: 7,906
