World Dryer Airforce J4-973A3 Motor Replacement
  1. World Dryer Airforce J4-973A3 Motor Replacement, Motor: step 1, image 1 of 3 World Dryer Airforce J4-973A3 Motor Replacement, Motor: step 1, image 2 of 3 World Dryer Airforce J4-973A3 Motor Replacement, Motor: step 1, image 3 of 3
    • To change the motor, start by removing the metal casing.
    • Using the special bit, remove the large screws at the bottom of the casing.
    • To remove the case, lift the indicated spot with your hands.
    • The direction for turning the screws is different than what was indicated on the small sticker above the hole.
    Ask FixBot
  2. World Dryer Airforce J4-973A3 Motor Replacement: step 2, image 1 of 3 World Dryer Airforce J4-973A3 Motor Replacement: step 2, image 2 of 3 World Dryer Airforce J4-973A3 Motor Replacement: step 2, image 3 of 3
    • Remove the three 1/2" Ph1 screws at the bottom of the red fan cap.
    • Turn over the device.
    • Push the red tabs on the back of the unit with medium to heavy pressure, using a small prier.
    • Carefully remove the cap, to prevent damage to the sensor.
    Ask FixBot
  3. World Dryer Airforce J4-973A3 Motor Replacement: step 3, image 1 of 2 World Dryer Airforce J4-973A3 Motor Replacement: step 3, image 2 of 2
    • Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom.
    • Lift the grey belt away. This gives access to the server board.
    Ask FixBot
  4. World Dryer Airforce J4-973A3 Motor Replacement: step 4, image 1 of 1
    • Use a plastic opening tool to remove the two pink capped wires in the upper left corner of the server board.
    Ask FixBot
  5. World Dryer Airforce J4-973A3 Motor Replacement: step 5, image 1 of 3 World Dryer Airforce J4-973A3 Motor Replacement: step 5, image 2 of 3 World Dryer Airforce J4-973A3 Motor Replacement: step 5, image 3 of 3
    • Remove the brass nut from its bolt using a 10mm wrench.
    • Once the nut is free, disconnect the green wire.
    Ask FixBot
  6. World Dryer Airforce J4-973A3 Motor Replacement: step 6, image 1 of 3 World Dryer Airforce J4-973A3 Motor Replacement: step 6, image 2 of 3 World Dryer Airforce J4-973A3 Motor Replacement: step 6, image 3 of 3
    • Remove the rainbow ribbon cable using a plastic opening tool.
    • Remove the 1/2" Ph1 screw from the center of the circuit board.
    Ask FixBot
  7. World Dryer Airforce J4-973A3 Motor Replacement: step 7, image 1 of 3 World Dryer Airforce J4-973A3 Motor Replacement: step 7, image 2 of 3 World Dryer Airforce J4-973A3 Motor Replacement: step 7, image 3 of 3
    • Remove the four 3/4" Ph2 screws from the back of the device body.
    • Separate the motor housing from the device body.
    • Ensure that all wires connecting the motor housing and motherboard are disconnected before removing the component.
    Ask FixBot
  8. World Dryer Airforce J4-973A3 Motor Replacement: step 8, image 1 of 3 World Dryer Airforce J4-973A3 Motor Replacement: step 8, image 2 of 3 World Dryer Airforce J4-973A3 Motor Replacement: step 8, image 3 of 3
    • Remove the four 1/2" Ph2 screws from the filter.
    • Pull the filter plate away to reveal the motor.
    Ask FixBot
  9. World Dryer Airforce J4-973A3 Motor Replacement: step 9, image 1 of 3 World Dryer Airforce J4-973A3 Motor Replacement: step 9, image 2 of 3 World Dryer Airforce J4-973A3 Motor Replacement: step 9, image 3 of 3
    • Pull the motor out of the housing.
    • Be sure to feed the wires through the slot as you pull the motor out.
    Ask FixBot
Eli Forbes
172 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 79
All Time: 658
