Up to 20% off select tools
Wooting 60HE Keycap Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
Past 7 Days:
28
Past 30 Days:
147
All Time:
2,070
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
Often times with many keyboards, especially this one, certain keys may experience a lag, or may just not register at all. The majority of the time, it is due to debris being present inside the keyboard, preventing the proper connection when a key is pressed. In this guide, we will be going through a detailed step-by-step process on how to replace a Wooting 60HE keycap.
Wear gloves at all times during this replacement to help prevent the oils from your skin coming into contact with the keyboard's lubricant.
    1. Wooting 60HE Keycap Replacement, Keycap: step 1, image 1 of 1
      • Use a small, soft bristle brush to remove small hairs or dust from the keyboard.
      • For this replacement, we will be replacing the "A" keycap.
      Ask FixBot
    2. Wooting 60HE Keycap Replacement: step 2, image 1 of 2 Wooting 60HE Keycap Replacement: step 2, image 2 of 2
      • Hook the two metal brackets of the keycap puller at a slight angle on the corners of the key.
      • Slightly tug upwards, and the key should come out smoothly. Place the key to the side.
      • It is essential to be gentle; excessive force can cause cracks or scratches on the key.
      Ask FixBot
    3. Wooting 60HE Keycap Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers, carefully extract debris from the exposed backboard of the keyboard.
      • Try to avoid the key nub, as it is lubricated, and outside contact can ruin it.
      Ask FixBot
    4. Wooting 60HE Keycap Replacement: step 4, image 1 of 1
      • Hold a multi-purpose electronics duster three inches away and at an angle from the exposed key.
      • Press the trigger in short bursts.
      • This will help get rid of any debris that you could not get from using your tweezers.
      Ask FixBot
    5. Wooting 60HE Keycap Replacement: step 5, image 1 of 2 Wooting 60HE Keycap Replacement: step 5, image 2 of 2
      • Place a cotton swab on a napkin and lightly coat the head of the swab with 70% isopropyl alcohol.
      Ask FixBot
    6. Wooting 60HE Keycap Replacement: step 6, image 1 of 1
      • Gently pat around the white backboard of the keyboard with the cotton swab.
      • This will help get rid of any built up residue, oils, or any possible spills that could have occurred in the past.
      • Isopropyl alcohol can strip the lubricant on the key, so put emphasis on dabbing the white backboard and not the key itself.
      Ask FixBot
    7. Wooting 60HE Keycap Replacement: step 7, image 1 of 3 Wooting 60HE Keycap Replacement: step 7, image 2 of 3 Wooting 60HE Keycap Replacement: step 7, image 3 of 3
      • Line the keycap in the upright position above the nub and press down lightly.
      • The key should slide back in place.
      Ask FixBot
Finish Line
Author
with
Aryav Balia
157 Reputation
1 Guide authored
CSU Los Angeles, Team 1-1, Briggs Fall 2023 Member of CSU Los Angeles, Team 1-1, Briggs Fall 2023
CSULA-BRIGGS-F23S1G1
6 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 28
Past 30 Days: 147
All Time: 2,070
