Wooden Fence Picket Replacement
    1. Wooden Fence Picket Replacement, Picket: step 1, image 1 of 3 Wooden Fence Picket Replacement, Picket: step 1, image 2 of 3 Wooden Fence Picket Replacement, Picket: step 1, image 3 of 3
      • IMPORTANT: This step will need to be completed before continuing. You will need to use these measurements to purchase a replacement picket needed later in the guide.
      • Use the tape measure to measure the height, width, and depth of the picket.
      • Use these measurements to purchase a replacement picket. Home Depot and Lowe's are good places to purchase a picket. If you are unfamiliar with what you are doing, ask any worker there for some help and they will help you get your replacement.
      Ask FixBot
    2. Wooden Fence Picket Replacement: step 2, image 1 of 3 Wooden Fence Picket Replacement: step 2, image 2 of 3 Wooden Fence Picket Replacement: step 2, image 3 of 3
      • Place the tip of the pry bar under the picket, in line with the nails.
      • Use a hammer to push the pry bar under the picket.
      • Use soft taps with the hammer when hitting the pry bar. Using too much force may reduce accuracy and lead to injury.
      • Pull the pry bar away from the fence to remove the picket.
      Ask FixBot
    3. Wooden Fence Picket Replacement: step 3, image 1 of 3 Wooden Fence Picket Replacement: step 3, image 2 of 3 Wooden Fence Picket Replacement: step 3, image 3 of 3
      • Only complete this step if there are still nails in the wood after you have removed the picket. If all nails are removed, continue to Step 4.
      • Slide the claw of the hammer underneath the nail.
      • The claw is the forked area of the hammer. This is commonly used to aid in the removal of nails.
      • While holding the handle, pull on the hammer to remove the nail.
      Ask FixBot
    4. Wooden Fence Picket Replacement: step 4, image 1 of 3 Wooden Fence Picket Replacement: step 4, image 2 of 3 Wooden Fence Picket Replacement: step 4, image 3 of 3
      • Before installing the new picket, clear the area of any debris.
      • Obstructions may cause the picket to be crooked when installing, or make a gap too large for the nails to work properly.
      • Use the tape measure to measure the gaps between the left and right side of the picket.
      • Doing this allows the replacement picket to be centered directly between the other pickets.
      Ask FixBot
    5. Wooden Fence Picket Replacement: step 5, image 1 of 3 Wooden Fence Picket Replacement: step 5, image 2 of 3 Wooden Fence Picket Replacement: step 5, image 3 of 3
      • Caution: This step involves hitting nails with a hammer in close proximity to your fingers. Work gloves are recommended if you are unfamiliar with using a hammer.
      • Hold a wood nail approximately 1 inch from the side of the picket.
      • You may place the first nail 1 inch away from either the left or right side of the picket. Each section uses 2 nails so it does not matter which side you choose to work on first.
      • Lightly tap on the wood nail with the hammer to begin pushing the nail into the picket. Continue until the nail is fully in the picket.
      • Repeat until there are 2 nails inserted in the picket at every cross section.
      Ask FixBot
This guide only demonstrates how to replace a picket on a wooden fence. For questions regarding staining your fence and finding the right stain, I recommend talking with a worker at a hardware store near you. They can help you find the right product and make sure your new picket matches the rest of your fence.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 91
All Time: 3,826
