Wooden Chair Slat Replacement
    1. Wooden Chair Slat Replacement, Slat: step 1, image 1 of 3 Wooden Chair Slat Replacement, Slat: step 1, image 2 of 3 Wooden Chair Slat Replacement, Slat: step 1, image 3 of 3
      • Saw off the broken chair slat piece(s).
      Ask FixBot
    2. Wooden Chair Slat Replacement: step 2, image 1 of 2 Wooden Chair Slat Replacement: step 2, image 2 of 2
      • Remove the broken piece from the chair.
      • Sand down the chair where the piece was removed.
      Ask FixBot
    3. Wooden Chair Slat Replacement: step 3, image 1 of 3 Wooden Chair Slat Replacement: step 3, image 2 of 3 Wooden Chair Slat Replacement: step 3, image 3 of 3
      • Measure a wooden dowl similar in size to the chair slat.
      • Mark the measurement on the wooden dowel with a marker.
      • Cut the wooden dowel directly on the marked line.
      Ask FixBot
    4. Wooden Chair Slat Replacement: step 4, image 1 of 3 Wooden Chair Slat Replacement: step 4, image 2 of 3 Wooden Chair Slat Replacement: step 4, image 3 of 3
      • Sand the sawed-off end of the dowel.
      • Apply wood stain to the dowel piece to match the chair's color.
      • Apply wood stain following the direction of the wood grain.
      Ask FixBot
    5. Wooden Chair Slat Replacement: step 5, image 1 of 3 Wooden Chair Slat Replacement: step 5, image 2 of 3 Wooden Chair Slat Replacement: step 5, image 3 of 3
      • Let the wood stain dry.
      • Add wood glue to the top of the new slat piece.
      • Add wood glue to the base of the chair.
      Ask FixBot
    6. Wooden Chair Slat Replacement: step 6, image 1 of 3 Wooden Chair Slat Replacement: step 6, image 2 of 3 Wooden Chair Slat Replacement: step 6, image 3 of 3
      • Insert the new slat piece into the missing space.
      • Add the clamp to keep it in place for at least 30 minutes.
      Ask FixBot
    7. Wooden Chair Slat Replacement: step 7, image 1 of 2 Wooden Chair Slat Replacement: step 7, image 2 of 2
      • Let the slat piece dry for at least 24 hours.
      • The chair is then ready for use.
      Ask FixBot
Finish Line
Veronica Shedd
145 Reputation
1 Guide authored
UC Davis, Team 2-4, Whithaus Spring 2024 Member of UC Davis, Team 2-4, Whithaus Spring 2024
UCD-WHITHAUS-S24S2G4
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 59
All Time: 1,118
