Wood Stool Leg Glide Replacement
    1. Wood Stool Leg Glide Replacement, Wood Stool Leg Glides: step 1, image 1 of 1
      • Turn the stool upside down so it is stable on the ground and the legs are faced up in the air.
      Ask FixBot
    2. Wood Stool Leg Glide Replacement: step 2, image 1 of 1
      • Clean the end of the sled gliders and the legs to remove dust and debris.
      Ask FixBot
    3. Wood Stool Leg Glide Replacement: step 3, image 1 of 1
      • Peel the sled glides off of the top of the screw on glides on all four of the legs.
      Ask FixBot
    4. Wood Stool Leg Glide Replacement: step 4, image 1 of 1
      • Use a 1.59mm drill bit and unscrew the screw from all four legs. Then remove the screw on glides.
      • Make sure the drill is faced straight up and down or the screw will become stripped.
      Ask FixBot
    5. Wood Stool Leg Glide Replacement: step 5, image 1 of 1
      • Pry the remaining part of the screw with a hammer if the screw is not drilled out all of the way.
      Ask FixBot
    6. Wood Stool Leg Glide Replacement: step 6, image 1 of 1
      • Use a 1.59mm drill bit to drill on the new screw on glides in the center of all four stool legs.
      Ask FixBot
    7. Wood Stool Leg Glide Replacement: step 7, image 1 of 2 Wood Stool Leg Glide Replacement: step 7, image 2 of 2
      • Stick the new sled glider at the center of the screw on glides for all four legs.
      Ask FixBot
Molly Ristig
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 29
All Time: 860
