Womier K66 Mechanical Keyboard Switch Replacement
  1. Womier K66 Mechanical Keyboard Switch Replacement, Switch: step 1, image 1 of 3 Womier K66 Mechanical Keyboard Switch Replacement, Switch: step 1, image 2 of 3 Womier K66 Mechanical Keyboard Switch Replacement, Switch: step 1, image 3 of 3
    • Remove the keycaps from the keyboard using the keycap remover.
  2. Womier K66 Mechanical Keyboard Switch Replacement: step 2, image 1 of 3 Womier K66 Mechanical Keyboard Switch Replacement: step 2, image 2 of 3 Womier K66 Mechanical Keyboard Switch Replacement: step 2, image 3 of 3
    • Flip the keyboard over so the backside is facing up.
    • Use the Phillips #0 screwdriver to remove the fourteen 1.52 mm screws.
    • Remove the back plate of the keyboard.
  3. Womier K66 Mechanical Keyboard Switch Replacement: step 3, image 1 of 3 Womier K66 Mechanical Keyboard Switch Replacement: step 3, image 2 of 3 Womier K66 Mechanical Keyboard Switch Replacement: step 3, image 3 of 3
    Tool used on this step:
    Desoldering Pump
    $3.99
    Buy
    • If you're unfamiliar with solder or need a refresher, review the How to Solder and Desolder guide.
    • Set your soldering iron to 400 °C.
    • Apply the soldering iron to the solder joints and remove the solder with the desoldering pump.
    • Be careful when soldering as the iron is very hot.
  4. Womier K66 Mechanical Keyboard Switch Replacement: step 4, image 1 of 3 Womier K66 Mechanical Keyboard Switch Replacement: step 4, image 2 of 3 Womier K66 Mechanical Keyboard Switch Replacement: step 4, image 3 of 3
    • Remove the key switch from the board using the key switch puller.
  5. Womier K66 Mechanical Keyboard Switch Replacement: step 5, image 1 of 3 Womier K66 Mechanical Keyboard Switch Replacement: step 5, image 2 of 3 Womier K66 Mechanical Keyboard Switch Replacement: step 5, image 3 of 3
    • Place your new switch onto the board.
    • In this case we used a Gateron Linear switch but this could be any variety of switches.
  6. Womier K66 Mechanical Keyboard Switch Replacement: step 6, image 1 of 3 Womier K66 Mechanical Keyboard Switch Replacement: step 6, image 2 of 3 Womier K66 Mechanical Keyboard Switch Replacement: step 6, image 3 of 3
    • Apply new solder to the soldering joints of the replacement switch.
Minh-Tam Nguyen
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 68
All Time: 1,005
