Withings Smart Body Analyzer Motherboard Replacement
    1. Withings Smart Body Analyzer Motherboard Replacement, Withings Smart Body Analyzer Disassembly: step 1, image 1 of 1
      • Push the battery door
      • Open the compartment
      • Gently remove the batteries from their designated positions
      • Place them aside, away from the reach of children
      Ask FixBot
    2. Withings Smart Body Analyzer Motherboard Replacement: step 2, image 1 of 3 Withings Smart Body Analyzer Motherboard Replacement: step 2, image 2 of 3 Withings Smart Body Analyzer Motherboard Replacement: step 2, image 3 of 3
      • With caution, insert the plastic opening tools in between the disk and the glass face
      • It's a tight fit, so don't be afraid to apply a little bit of force
      • As soon as you hear a faint crackling sound, that means that the adhesive is budging out of place
      • Gently rotate the plastic spudger around the disk to get around the adhesive
      • Gently lift the metal disk
      • After the disk has been lifted, a wire and a small copper plate can be seen attached to the back of the disk
      • Carefully remove the wire and plate by peeling back the adhesive sticker that has been positioned around them
      Ask FixBot
    3. Withings Smart Body Analyzer Motherboard Replacement: step 3, image 1 of 2 Withings Smart Body Analyzer Motherboard Replacement: step 3, image 2 of 2
      • After all the above steps have been completed, proceed by removing the glass face
      • Carefully insert a plasic spudger in the small gap that exist in between the glass face and the plastic back
      • Run the plastic spudger all around the scale to increase the gap size
      • Place a plastic spudger in every corner, since the feet of the scale are also attached to the glass face using adhesive
      • Carefully insert the metal spudger underneath the adhesive that is located underneath the feet of the scale, and gently keep pushing until the adhesive is out of place
      • Repeat the above steps four times
      • After all the adhesives has been removed, gently lift the glass face off
      Ask FixBot
    1. Withings Smart Body Analyzer Motherboard Replacement, Motherboard: step 4, image 1 of 2 Withings Smart Body Analyzer Motherboard Replacement, Motherboard: step 4, image 2 of 2
      • Using the Phillips-head screwdriver, unscrew the two screws that are securing the motherboard in place
      Ask FixBot
    2. Withings Smart Body Analyzer Motherboard Replacement: step 5, image 1 of 1
      • Using a plastic spudger, disconnect the LCD display's ribbon cable from the motherboard.
      Ask FixBot
    3. Withings Smart Body Analyzer Motherboard Replacement: step 6, image 1 of 1
      • Once the two screws and the ribbon cable are detached, remove the motherboard.
      Ask FixBot
3 other people completed this guide.
Ashley Dauphinee
323 Reputation
2 Guides authored
2 Guide Comments
My Wifi Body scale cannot connect to Wifi or my app. Everything else works. Where can I have it repaired. Please advise.
Mel - Reply Share
where do you get the motherboard?
cost?
donald taylor - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 125
All Time: 8,182
