Wireless Xbox One Controller Bumper Assembly Replacement
    1. Wireless Xbox One Controller Bumper Assembly Replacement, Bumper Assembly: step 1, image 1 of 1
      • Remove the battery cover from the back of the controller by sliding it upwards.
      Ask FixBot
    2. Wireless Xbox One Controller Bumper Assembly Replacement: step 2, image 1 of 3 Wireless Xbox One Controller Bumper Assembly Replacement: step 2, image 2 of 3 Wireless Xbox One Controller Bumper Assembly Replacement: step 2, image 3 of 3
      Tool used on this step:
      Halberd Spudger
      $2.99
      Buy
      • Using the halberd spudger, pry the grip casing upwards from the handle.
      • Remove the grip casing from both the left and right handles of the controller.
      • It helps to begin near the top of the grip casing near the trigger.
      Ask FixBot
    3. Wireless Xbox One Controller Bumper Assembly Replacement: step 3, image 1 of 2 Wireless Xbox One Controller Bumper Assembly Replacement: step 3, image 2 of 2
      • Remove the five 9 mm Torx TR9 security screws from the top and bottom of the controller grip regions as well as from the center of the battery region.
      • The pins on the security screws can be broken off easily with a small flathead screwdriver for use of an ordinary Torx screwdriver if the security version is unavailable.
      Ask FixBot
    4. Wireless Xbox One Controller Bumper Assembly Replacement: step 4, image 1 of 1
      • Remove the back of the controller casing by lifting it up and off.
      Ask FixBot
    5. Wireless Xbox One Controller Bumper Assembly Replacement: step 5, image 1 of 1
      • Lift the internal assembly from the plastic controller case.
      • Handle gently; the motors on the bottom left and right are not firmly attached.
      Ask FixBot
    6. Wireless Xbox One Controller Bumper Assembly Replacement: step 6, image 1 of 2 Wireless Xbox One Controller Bumper Assembly Replacement: step 6, image 2 of 2
      • Remove the top button panel from the controller by gently lifting up the hooks attached to the internals.
      Ask FixBot
    7. Wireless Xbox One Controller Bumper Assembly Replacement: step 7, image 1 of 1
      • Detach the bumper assembly by sliding one bumper to the side away from the controller and then lifting upwards.
      • Gently follow the motion indicated by the arrows.
      Ask FixBot
    8. Wireless Xbox One Controller Bumper Assembly Replacement: step 8, image 1 of 1
      • Remove bumpers and replace by inserting a new bumper assembly.
      Ask FixBot
18 other people completed this guide.
Patrick Ashman
449 Reputation
1 Guide authored
Cal Poly, Team 2-2, Johann Winter 2023 Member of Cal Poly, Team 2-2, Johann Winter 2023
CPSU-JOHANN-W23S2G2
3 Members
12 Guides authored
1 Guide Comment
hie my controller vibrate and goes off immediately I start using it kindly assist
Shakes makena - Reply Share
Past 24 Hours: 28
Past 7 Days: 152
Past 30 Days: 705
All Time: 21,209
