Up to 20% off select tools
Wireless LAN card Replacement
Views: 2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
36
Past 30 Days:
144
All Time:
1,999
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your wireless LAN card is damaged or broken or you're having trouble connecting to WiFi with your laptop, replace Wireless LAN card using this guide.
    1. Wireless LAN card Replacement, Back Panel: step 1, image 1 of 2 Wireless LAN card Replacement, Back Panel: step 1, image 2 of 2
      • Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
      Ask FixBot
    2. Wireless LAN card Replacement: step 2, image 1 of 2 Wireless LAN card Replacement: step 2, image 2 of 2
      • Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
      Ask FixBot
    1. Wireless LAN card Replacement, Wireless LAN card: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Use the tweezers to remove the two connecting wires.
      Ask FixBot
    2. Wireless LAN card Replacement: step 4, image 1 of 1
      • Using the Phillips #1 screwdriver, remove the two 2.5mm screws holding down the card.
      Ask FixBot
    3. Wireless LAN card Replacement: step 5, image 1 of 1
      • Lift and pull the Wireless LAN card away from the computer.
      Ask FixBot
Author
with
Armani Tayeh
447 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 36
Past 30 Days: 144
All Time: 1,999
