Up to 20% off select tools
Wire Stripping
Views: 15K
View statistics:
Past 24 Hours:
10
Past 7 Days:
70
Past 30 Days:
389
All Time:
14,757
Comments: 0
Go to guide comments
Completed: 24
24 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 3 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Wire Stripping
Tools
Introduction
Go to step 1 ↓
Wire needs to be exposed from its insulation in order before it can be soldered to another wire. Wire stripping exposes the wire so you are able to make good connections.
    1. Wire Stripping, Wire Stripping: step 1, image 1 of 1
      • Match your gauge of wire to the gauge on a wire stripper.
      • Some wire strippers will have two gauge sizes for the same hole, one for solid wire and one for stranded. Make sure you use the right one for the wire you are stripping!
      Ask FixBot
    2. Wire Stripping: step 2, image 1 of 1
      • Place the wire stripper about a 1/4” from the end of the wire and squeeze down.
      • You can strip more than 1/4" at a time, but the effort becomes harder. About 1/2-5/8" (13-16 mm) is the most you should probably attempt.
      Ask FixBot
    3. Wire Stripping: step 3, image 1 of 1
      • While squeezing, pull the stripper toward the end of the wire. This should expose some of the wire by removing its insulation.
      Ask FixBot
After your wire has been stripped, the exposed wire is ready to be soldered and reconnected to other parts of the microphone.
24 other people completed this guide.
Author
with
nat coll
868 Reputation
14 Guides authored
Cal Poly, Team 7-53, Forte Fall 2012 Member of Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Members
180 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 70
Past 30 Days: 389
All Time: 14,757
