Up to 20% off select tools
Wire Bonder Thread Spool Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
22
Past 30 Days:
75
All Time:
591
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 - 3 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This description takes you through the steps of changing a spool and feeding a new thread into the wire bonder.
Video Overview
    1. Wire Bonder Thread Spool Replacement, Wire Bonder Thread Spool Replacement: step 1, image 1 of 1
      • Remove the seal from the wire spool. Take care not to cut the thread at the red marking!
      Ask FixBot
    2. Wire Bonder Thread Spool Replacement: step 2, image 1 of 1
      • Insert the spool in the assembly.
      • Make sure that the spool runs clockwise.
      Ask FixBot
      • Pull the thread downward.
      Ask FixBot
    3. Wire Bonder Thread Spool Replacement, Placing the thread into the infeeder: step 4, image 1 of 1
      • Place the thread between the guides of the infeeder.
      • Pull the engaging knob which is situated to the left of the infeeder rolls, to the left.
      • Now there is a gap between the infeeder rolls into which the wire can be inserted safely.
      Ask FixBot
    4. Wire Bonder Thread Spool Replacement, Placing the thread behind the sensors: step 5, image 1 of 1
      • Cut the wire.
      • Place the wire behind the sensors (the black box in the foreground).
      Ask FixBot
    5. Wire Bonder Thread Spool Replacement, Placing the thrad in the outfeeder: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Use the tweezers to place the wire between the two metal guides of the outfeeder.
      Ask FixBot
    6. Wire Bonder Thread Spool Replacement, Put the wire into the tube: step 7, image 1 of 1
      • Use the tweezers to lead the wire into the tube from below.
      Ask FixBot
    7. Wire Bonder Thread Spool Replacement, Automatic feeding: step 8, image 1 of 1
      • Push the spring of the outfeeder and the "Feed and Capture" button simultaneously for automatic feeding.
      • Make sure that the rolls of the outfeeder are close together so that the wire is gripped firmly.
      • Before starting automatic feeding, turn off "Run or Service" and activate "Feed or Capture".
      Ask FixBot
    8. Wire Bonder Thread Spool Replacement, Manual Feeding: step 9, image 1 of 2 Wire Bonder Thread Spool Replacement, Manual Feeding: step 9, image 2 of 2
      • It is also possible to feed the wire manually into the outfeeder tube.
      • In order to do so, press the "Run and Service" button and turn the left-hand wheel clockwise. The wire is now fed ino the tube.
      Ask FixBot
    9. Wire Bonder Thread Spool Replacement: step 10, image 1 of 1
      • Check visually if the wire is fed into the bonding head.
      Ask FixBot
Author
with
Beate Richter
181 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 75
All Time: 591
