Up to 20% off select tools
Wintec Filemate Clear 7" Battery Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
104
All Time:
1,608
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
  • Spudger
    4.9
  • iFixit Opening Tool
    4.8
  • Tweezers
Introduction
Go to step 1 ↓
in order to complete this guide, you will need to remove the battery, put a new one in its place, and solder the new connections onto the motherboard.
    1. Wintec Filemate Clear 7" Battery Replacement, Remove the Backplate: step 1, image 1 of 1
      • Locate the four corners of the backplate.
      Ask FixBot
    2. Wintec Filemate Clear 7" Battery Replacement: step 2, image 1 of 2 Wintec Filemate Clear 7" Battery Replacement: step 2, image 2 of 2
      • Pry off the backplate by inserting a spudger or plastic opening tool into each corner and popping them open.
      Ask FixBot
    1. Wintec Filemate Clear 7" Battery Replacement, Remove the Battery: step 3, image 1 of 1
      • Un-stick the battery from the motherboard assembly with the plastic opening tool.
      Ask FixBot
    2. Wintec Filemate Clear 7" Battery Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Desolder the battery wires from the motherboard.
      • The tweezers pictured point to the two solder joints.
      Ask FixBot
    3. Wintec Filemate Clear 7" Battery Replacement: step 5, image 1 of 1
      • Fully remove the battery from the device.
      Ask FixBot
To reassemble your device, glue the new battery to where the old one was and solder the new power connectors where the old ones were. Then follow the instructions in reverse order.
3 other people completed this guide.
Author
with
Nicholas Ferraro
431 Reputation
6 Guides authored
USF Tampa, Team 19-6, Blackwell Spring 2014 Member of USF Tampa, Team 19-6, Blackwell Spring 2014
USFT-BLACKWELL-S14S19G6
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 104
All Time: 1,608
