Up to 20% off select tools
Wine Cooler Fan replacement
Views: 37K
View statistics:
Past 24 Hours:
7
Past 7 Days:
51
Past 30 Days:
279
All Time:
36,839
Comments: 22
22 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Often a wine cooler is replaced because of a noise problem. Often a $10 fix
      • The Cuisinart - Private Reserve 16-Bottle Wine Cellar often is replaced because the cooling fan becomes noisy.
      Ask FixBot
      • The original fan has a sleeved bearing (which becomes noisy as the lubrication wears out) and you can replace this fan with a ball bearing fan for around $10
      Ask FixBot
      • The replacement 12 VDC fan may have an additional wire (yellow) but it is not needed, just splice in the red and black wires to the original connector.
      Ask FixBot
      • when you order a replacement fan. measure the diameter (usually 4x4) and the thickness, to make sure it fits under the rear cover.
      Ask FixBot
      • To access the fan - unplug the unit. Remove the rear cover with a #2 phillips screw driver. Once the cover is off you will see the fan and it is held on by 4 small screws and nuts. The electrical connector location on the circuit board is labeled "fan". Carefully unplug the connector and remove the fan.
      Ask FixBot
for around $10 you have a working wine cooler
8 other people completed this guide.
Author
with
Michael Williams
918 Reputation
8 Guides authored
22 Guide Comments
What direction do the fans need to blow? Into the fridge or out? I took the fans out and didn't look what way they were blowing
Steve - Reply Share
You want the heat to be blown out.
Michael Williams - Reply Share
Mine is a Koolatron 24 bottles dual compartments wine fridge. It is a thermoelectric model. Each compartment has two fans - one that is visible when the back is removed and the second further inside. There is a cooling module on a heat sink between the two fans. I was informed that the exterior fan must blow towards the module( drawing in room temperature air and blowing it along the “heat side” of the module) and the inside fan must blow into the fridge (drawing the cold from the “cooling side” of the module and blowing it into the fridge) Does sound correct to you?
Louis Kohn - Reply Share
How do I order a brushless DC fan model #9025S and from where?
thank you,
Skip M.
Skip McDowell - Reply Share
I had to order a replacement from the manufacturer in China. I Googled the name on the fan and found the site. I ordered 2 replacements as my cooler has 2 levels. $14 and free shipping, but it won’t be here for 2 months. You might try entering the fan specs on your search engine (brushless fan whatever volts, amps, size). I got some hits on that but the amperage was too high as I need 0.8 amps. Good luck.
Donna Brinkoetter - Reply Share
Past 24 Hours: 7
Past 7 Days: 51
Past 30 Days: 279
All Time: 36,839
