Windsor Willow Rear Wheel Replacement
  1. Windsor Willow Rear Wheel Replacement, Chain: step 1, image 1 of 1
    • The chain connects the crank arm to the gear cluster on the back wheel.
    Ask FixBot
  2. Windsor Willow Rear Wheel Replacement: step 2, image 1 of 1
    • On the chain, locate the master link. It is a lighter gray than the other links of the chain. This is how you can break the chain for easier removal.
    Ask FixBot
  3. Windsor Willow Rear Wheel Replacement: step 3, image 1 of 2 Windsor Willow Rear Wheel Replacement: step 3, image 2 of 2
    • To separate the Master Link, hold the left side of the link in your left hand and the link to the right in your right hand. Push the two links together to enable the release. Pull the links apart, one hand moving towards yourself and the other away from you. This will separate the links of the chain.
    Ask FixBot
  4. Windsor Willow Rear Wheel Replacement: step 4, image 1 of 1
    • Once you have separated the links of the chain, pull down on the right side of the chain as shown. Pull until the chain has been fully removed from the gears. Place the chain on a paper towel or cloth to prevent getting grease anywhere.
    Ask FixBot
  5. Windsor Willow Rear Wheel Replacement, Rear Wheel: step 5, image 1 of 1
    • Hold the bicycle so that the bicycle wheels rests in the air and able to stand on its own.
    Ask FixBot
  6. Windsor Willow Rear Wheel Replacement: step 6, image 1 of 2 Windsor Willow Rear Wheel Replacement: step 6, image 2 of 2
    • Open the sidepull brakes by fully rotating the title lever on the brake upwards.
    Ask FixBot
  7. Windsor Willow Rear Wheel Replacement: step 7, image 1 of 2 Windsor Willow Rear Wheel Replacement: step 7, image 2 of 2
    • To loosen the wheel, simply pull out the lever, away from the frame and loosen up.
    Ask FixBot
  8. Windsor Willow Rear Wheel Replacement: step 8, image 1 of 1
    • When the quick release is opened, the wheel is ready to remove.
    Ask FixBot
Zin
102 Reputation
1 Guide authored
Cal Poly, Team 10-6, Banghart Winter 2017 Member of Cal Poly, Team 10-6, Banghart Winter 2017
CPSU-BANGHART-W17S10G6
5 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 369
