Windsor Willow Derailleur Replacement
  1. Windsor Willow Derailleur Replacement, Chain: step 1, image 1 of 1
    • The chain connects the crank arm to the gear cluster on the back wheel.
    Ask FixBot
  2. Windsor Willow Derailleur Replacement: step 2, image 1 of 1
    • On the chain, locate the master link. It is a lighter gray than the other links of the chain. This is how you can break the chain for easier removal.
    Ask FixBot
  3. Windsor Willow Derailleur Replacement: step 3, image 1 of 2 Windsor Willow Derailleur Replacement: step 3, image 2 of 2
    • To separate the Master Link, hold the left side of the link in your left hand and the link to the right in your right hand. Push the two links together to enable the release. Pull the links apart, one hand moving towards yourself and the other away from you. This will separate the links of the chain.
    Ask FixBot
  4. Windsor Willow Derailleur Replacement: step 4, image 1 of 1
    • Once you have separated the links of the chain, pull down on the right side of the chain as shown. Pull until the chain has been fully removed from the gears. Place the chain on a paper towel or cloth to prevent getting grease anywhere.
    Ask FixBot
  5. Windsor Willow Derailleur Replacement, Rear Wheel: step 5, image 1 of 1
    • Hold the bicycle so that the bicycle wheels rests in the air and able to stand on its own.
    Ask FixBot
  6. Windsor Willow Derailleur Replacement: step 6, image 1 of 2 Windsor Willow Derailleur Replacement: step 6, image 2 of 2
    • Open the sidepull brakes by fully rotating the title lever on the brake upwards.
    Ask FixBot
  7. Windsor Willow Derailleur Replacement: step 7, image 1 of 2 Windsor Willow Derailleur Replacement: step 7, image 2 of 2
    • To loosen the wheel, simply pull out the lever, away from the frame and loosen up.
    Ask FixBot
  8. Windsor Willow Derailleur Replacement: step 8, image 1 of 1
    • When the quick release is opened, the wheel is ready to remove.
    Ask FixBot
  9. Windsor Willow Derailleur Replacement, Loosen the Hex Bolt and Free the Derailleur Cable: step 9, image 1 of 1
    • Loosen the hex nut, as shown, on the side of the derailleur. This bolt plays a key role in securing the derailleur cable which we will need to cut in step two.
    Ask FixBot
  10. Windsor Willow Derailleur Replacement, Cut the Derailleur Cable: step 10, image 1 of 3 Windsor Willow Derailleur Replacement, Cut the Derailleur Cable: step 10, image 2 of 3 Windsor Willow Derailleur Replacement, Cut the Derailleur Cable: step 10, image 3 of 3
    • Using a pair of wire cutters, locate the end of the derailleur cable. Cut the wire just below the cap, cutting off the metal end piece.
    Ask FixBot
  11. Windsor Willow Derailleur Replacement, Remove Derailleur from Frame: step 11, image 1 of 2 Windsor Willow Derailleur Replacement, Remove Derailleur from Frame: step 11, image 2 of 2
    • Using a hex key wrench, unscrew the bolt that fastens the derailleur to the bike frame. The derailleur should come off easily because it is no longer fastened to the bike and the derailleur cable can easily slip out.
    Ask FixBot
Ethan
201 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 37
All Time: 456
