Wilwood 195BH Winterization
    1. Wilwood 195BH Winterization, Exterior 1 - Patch the holes: step 1, image 1 of 3 Wilwood 195BH Winterization, Exterior 1 - Patch the holes: step 1, image 2 of 3 Wilwood 195BH Winterization, Exterior 1 - Patch the holes: step 1, image 3 of 3
      • The undersides of the trailers are only protected by a tarpaulin.
      • Items passing through this tarp leave openings for rodents or other insects
      • Patch those holes with duck tape
      Ask FixBot
    2. Wilwood 195BH Winterization, Exterior 2 - Exterior cleaning: step 2, image 1 of 1
      • With a soft brush and a soap brush clean the exterior of the trailer
      • Make sure it's completely dry before bringing it indoors if that's what you're doing.
      Ask FixBot
    3. Wilwood 195BH Winterization, Exterior 3 - Bumper cleaning: step 3, image 1 of 2 Wilwood 195BH Winterization, Exterior 3 - Bumper cleaning: step 3, image 2 of 2
      • After the exterior cleaning, it is an ideal moment to rinse with plenty of water the bumper which also serves as a storage for the sewer pipe.
      • Thoroughly rinse the inner bumper
      • Thoroughly rinse the pipe
      • Leave everything to air dry for a day.
      • A good idea to suspend the pipe so that it drips completely
      • Put it all back in the bumper
      Ask FixBot
    4. Wilwood 195BH Winterization, Inside 1 - Refrigerated Defrost: step 4, image 1 of 3 Wilwood 195BH Winterization, Inside 1 - Refrigerated Defrost: step 4, image 2 of 3 Wilwood 195BH Winterization, Inside 1 - Refrigerated Defrost: step 4, image 3 of 3
      • Close the refrigerator by pressing OFF
      • Taking tea towels, place it at the bottom of the refrigerator and leave the door open
      Ask FixBot
    5. Wilwood 195BH Winterization, Interior 2 - Fridge - cool: step 5, image 1 of 3 Wilwood 195BH Winterization, Interior 2 - Fridge - cool: step 5, image 2 of 3 Wilwood 195BH Winterization, Interior 2 - Fridge - cool: step 5, image 3 of 3
      • The next day, clean dry the inside
      • Place baking soda during hibernation
      • Place scraps of wood so that the freezer compartment can breathe and have air
      • If possible open the door ajar during hibernation
      Ask FixBot
    6. Wilwood 195BH Winterization, Interior 3 - Clean the tank: step 6, image 1 of 3 Wilwood 195BH Winterization, Interior 3 - Clean the tank: step 6, image 2 of 3 Wilwood 195BH Winterization, Interior 3 - Clean the tank: step 6, image 3 of 3
      • With a jet nozzle clean the toilet until no more deposits remain and your outlet water is clear
      • If you are not connected to a drain, you can use a bucket and gloves
      • This is the last step where you have running water in the trailer
      Ask FixBot
    7. Wilwood 195BH Winterization, Water heater 1 - Closing the valve: step 7, image 1 of 3 Wilwood 195BH Winterization, Water heater 1 - Closing the valve: step 7, image 2 of 3 Wilwood 195BH Winterization, Water heater 1 - Closing the valve: step 7, image 3 of 3
      • Make sure the heater has been completely shut down for a long time. RISK OF INJURY
      • Make sure the water is turned off before starting the conduit winterization steps
      • The valves are placed in such a way as to allocate cold water into the water heater and out. The cold-hot junction valve is closed
      • Open valves to prevent cold water from entering and hot water from exiting. Open the cold-hot junction valve
      Ask FixBot
    8. Wilwood 195BH Winterization, Water heater 2 - Water drain: step 8, image 1 of 3 Wilwood 195BH Winterization, Water heater 2 - Water drain: step 8, image 2 of 3 Wilwood 195BH Winterization, Water heater 2 - Water drain: step 8, image 3 of 3
      • To drain the water heater, the anode must be unscrewed with a 1 and 1/16 inch socket.
      • Note that I needed a 3/8 to 1/2 adapter to use the socket with my "ratchets"
      • Release pressure by pressing the valve repeatedly
      • Unscrew the anode completely and let the water flow completely out of the water heater
      • The teflon tape will be to replace that of the anode next spring
      • Once empty replace the anode
      Ask FixBot
    9. Wilwood 195BH Winterization, Antifreeze 1: step 9, image 1 of 3 Wilwood 195BH Winterization, Antifreeze 1: step 9, image 2 of 3 Wilwood 195BH Winterization, Antifreeze 1: step 9, image 3 of 3
      • The installation of a Tee was necessary so as not to have to dismantle the connector from the tank
      • Turn the valve down (for my system) and the pump will draw liquid from the food grade antifreeze container
      • Start the pump
      Ask FixBot
    10. Wilwood 195BH Winterization, Antifreeze 2: step 10, image 1 of 3 Wilwood 195BH Winterization, Antifreeze 2: step 10, image 2 of 3 Wilwood 195BH Winterization, Antifreeze 2: step 10, image 3 of 3
      • Make sure you've done step 7! Antifreeze MUST NOT enter the water heater!
      • Always one faucet at a time, start with the sink cold water stop when the antifreeze comes out fully pink
      • Continue with the hot water tap
      • Go use the toilet
      • Do NOT leave antifreeze in the bottom of the toilet all winter. Antifreeze stains plastic
      Ask FixBot
    11. Wilwood 195BH Winterization, Antifreeze 3: step 11, image 1 of 2 Wilwood 195BH Winterization, Antifreeze 3: step 11, image 2 of 2
      • Open bath cold water faucet, stop when antifreeze comes out
      • Do not forget to shower, water accumulates there.
      • Open hot water tap, stop when antifreeze comes out
      • Some models of shower nozzles need to be disassembled poorly resistant to cold. Plastic clips seem very fragile. For me, it's metal nets.
      Ask FixBot
    12. Wilwood 195BH Winterization, Finish 1: step 12, image 1 of 3 Wilwood 195BH Winterization, Finish 1: step 12, image 2 of 3 Wilwood 195BH Winterization, Finish 1: step 12, image 3 of 3
      • Take the fire extinguisher, shake it to stir the powder inside
      • You can knock it lightly on a padded surface
      • Remove any type of fabric likely to be undone by mice or rodents: tissues, paper towels, etc.
      • Finally, place Bounce sheets under mattresses and other pillows.
      • Placed in places near an exterior mouth keep mice and other rodents away with their scent
      Ask FixBot
    13. Wilwood 195BH Winterization, Finish 2: step 13, image 1 of 2 Wilwood 195BH Winterization, Finish 2: step 13, image 2 of 2
      • Disassemble the tank, tie the wires securely so they don't hang or catch anything along the way.
      • Burn the excess gas via the rings, the fridge, the water heater. As soon as the flame starter clicks stop
      Ask FixBot
    14. Wilwood 195BH Winterization, Finish 3: step 14, image 1 of 3 Wilwood 195BH Winterization, Finish 3: step 14, image 2 of 3 Wilwood 195BH Winterization, Finish 3: step 14, image 3 of 3
      • Close the circuit breakers so as not to draw all the energy from the battery of the towing vehicle during the trip to storage
      • Disconnect the battery and store it out of the gel on a wooden or plastic surface. Anything but concrete. Recharge the battery once or twice during the winter and before leaving with the trailer
      • Tie the battery wires securely
      • Open drain plugs to remove excess water
      Ask FixBot
    15. Wilwood 195BH Winterization, Storage: step 15, image 1 of 3 Wilwood 195BH Winterization, Storage: step 15, image 2 of 3 Wilwood 195BH Winterization, Storage: step 15, image 3 of 3
      • Possibility of leaving things that do not fear the cold. Plastic tips, empty and dry pipes, tools, etc.
      • Lock all compartments and doors.
      • Leave interior doors open during hibernation
      • If a Max-Air is present leave a very small gap on the roof vent
      Ask FixBot
In spring the steps are almost the opposite
2 other people completed this guide.
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Jacques Labrie
71 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 15
Past 30 Days: 45
All Time: 2,515
