Wiko pulp 4g Touch screen Replacement
    1. Wiko pulp 4g Touch screen Replacement, Touch screen: step 1, image 1 of 2 Wiko pulp 4g Touch screen Replacement, Touch screen: step 1, image 2 of 2
      • Remove back cover
      • Remove battery
      Ask FixBot
    2. Wiko pulp 4g Touch screen Replacement: step 2, image 1 of 1
      • remove the screws marked, attention is covered by a white sticker
      Ask FixBot
    3. Wiko pulp 4g Touch screen Replacement: step 3, image 1 of 2 Wiko pulp 4g Touch screen Replacement: step 3, image 2 of 2
      • using a thin tool separate the middle frame from the body display
      Ask FixBot
    4. Wiko pulp 4g Touch screen Replacement: step 4, image 1 of 2 Wiko pulp 4g Touch screen Replacement: step 4, image 2 of 2
      • unhook touchscreen connector
      Ask FixBot
    5. Wiko pulp 4g Touch screen Replacement: step 5, image 1 of 3 Wiko pulp 4g Touch screen Replacement: step 5, image 2 of 3 Wiko pulp 4g Touch screen Replacement: step 5, image 3 of 3
      • Remove 2 screws securing the motherboard
      • Unfasten the connectors
      • remove front and rear cameras
      Ask FixBot
    6. Wiko pulp 4g Touch screen Replacement: step 6, image 1 of 3 Wiko pulp 4g Touch screen Replacement: step 6, image 2 of 3 Wiko pulp 4g Touch screen Replacement: step 6, image 3 of 3
      • Unhook cable connection between top and bottom card
      • remove top motherboard
      Ask FixBot
    7. Wiko pulp 4g Touch screen Replacement: step 7, image 1 of 3 Wiko pulp 4g Touch screen Replacement: step 7, image 2 of 3 Wiko pulp 4g Touch screen Replacement: step 7, image 3 of 3
      • Heat the phone with a 80-degree plate or with an appropriate dryer
      • With the help of tools or special thin wire begin to separate from the touch glass display
      • Utmost care not to break the display, be sure to insert between the touch screen display instruments and not between glass and touch screen ..
      • There are no flat key is therefore the only attention to the display
      Ask FixBot
    8. Wiko pulp 4g Touch screen Replacement: step 8, image 1 of 2 Wiko pulp 4g Touch screen Replacement: step 8, image 2 of 2
      • Clean the display from the sticky residue
      • applying adhesive on the edges and the new touchscreen glass
      Ask FixBot
To assemble the device, follow these instructions in reverse order.
8 other people completed this guide.
Special thanks to these translators:
it en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Smilzo
12,380 Reputation
39 Guides authored
4 Guide Comments
I replaced a screen on a Acer Wiko Lenny 2 - was very simular to this one. I followed all these steps and it is working BUT the display does not respond as it should. Almost all touches on the outside border of the screen (for example, digit 1 on the left, digit 0 on the right) don't respond quickly, or don't respond at all. What could be wrong? If wonder if I didn't clean the digitizer properly enough...
Jan Oelbrandt - Reply Share
sorry for the delay.
I had some problem with the touch screen too much more intrusive than yours.
I have secured the edges well with scotch because it does not contact me.
But these Chinese touchscreens do not have good quality so I prefer to buy a screen mounted with touchscreen, so I save a lot of time and work is better and working
Smilzo - Reply Share
Ciao, come fai a rimuovere i residui di colla dal display, una volta tolto il vetro?
Roberto Oboe - Reply Share
Scaldando e con una spatolina ed anche con il puliscicontatti spray
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 116
All Time: 8,324
