Wii U GamePad LCD Display Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Video Overview
    1. Wii U GamePad LCD Display Replacement, Battery: step 1, image 1 of 1
      • Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
      Ask FixBot
    2. Wii U GamePad LCD Display Replacement: step 2, image 1 of 1
      • Lift and remove the battery plate.
      Ask FixBot
    3. Wii U GamePad LCD Display Replacement: step 3, image 1 of 3 Wii U GamePad LCD Display Replacement: step 3, image 2 of 3 Wii U GamePad LCD Display Replacement: step 3, image 3 of 3
      • With your finger, press down and pull back on the battery connector plug.
      • Remove the battery from the battery case.
      Ask FixBot
    1. Wii U GamePad LCD Display Replacement, Outer Case: step 4, image 1 of 3 Wii U GamePad LCD Display Replacement, Outer Case: step 4, image 2 of 3 Wii U GamePad LCD Display Replacement, Outer Case: step 4, image 3 of 3
      • Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
      • Lift up on the back of case.
      • Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
      Ask FixBot
    2. Wii U GamePad LCD Display Replacement: step 5, image 1 of 1
      • Unplug outer case rumble motor connector from the motherboard with your fingers.
      • Do not pull on the wires as shown in this picture, they will likely break off. Pull directly on the plug (NOT the receptacle)
      Ask FixBot
    1. Wii U GamePad LCD Display Replacement, Speakers: step 6, image 1 of 2 Wii U GamePad LCD Display Replacement, Speakers: step 6, image 2 of 2
      • With your fingers, unplug the left speaker cable from the motherboard.
      Ask FixBot
    2. Wii U GamePad LCD Display Replacement: step 7, image 1 of 2 Wii U GamePad LCD Display Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the right speaker cable that's connected to the motherboard with the tweezers.
      Ask FixBot
    1. Wii U GamePad LCD Display Replacement, Wi-Fi Board: step 8, image 1 of 3 Wii U GamePad LCD Display Replacement, Wi-Fi Board: step 8, image 2 of 3 Wii U GamePad LCD Display Replacement, Wi-Fi Board: step 8, image 3 of 3
      Buy
      • Open the top and bottom clasp that connects the white flex cable to the motherboard with the tweezer.
      • Remove the white flex cable with the tweezers.
      Ask FixBot
    2. Wii U GamePad LCD Display Replacement: step 9, image 1 of 2 Wii U GamePad LCD Display Replacement: step 9, image 2 of 2
      • With your fingers, lift and remove Wi-Fi board.
      • Remove the board carefully as there are still two wires attached.
      Ask FixBot
    3. Wii U GamePad LCD Display Replacement: step 10, image 1 of 2 Wii U GamePad LCD Display Replacement: step 10, image 2 of 2
      • Disconnect the black and white wires off of the back of the Wi-Fi module.
      Ask FixBot
    4. Wii U GamePad LCD Display Replacement: step 11, image 1 of 1
      • Lift and remove the Wi-Fi module.
      Ask FixBot
    1. Wii U GamePad LCD Display Replacement, Motherboard: step 12, image 1 of 1
      Buy
      • Disconnect the analog connector with tweezers.
      Ask FixBot
    2. Wii U GamePad LCD Display Replacement: step 13, image 1 of 2 Wii U GamePad LCD Display Replacement: step 13, image 2 of 2
      • Remove the blue connector using tweezers.
      Ask FixBot
    3. Wii U GamePad LCD Display Replacement: step 14, image 1 of 2 Wii U GamePad LCD Display Replacement: step 14, image 2 of 2
      • Carefully lift the black clasp. It is prone to breaking if only lifted from one point. Remove the brown ribbon by using the tweezers.
      • Unclasp and release the small digitizer ribbon cable to the left of the brown ribbon.
      • Be careful, the small clasp breaks easily.
      Ask FixBot
    4. Wii U GamePad LCD Display Replacement: step 15, image 1 of 1
      • Remove the small orange ribbon with the tweezers.
      Ask FixBot
    5. Wii U GamePad LCD Display Replacement: step 16, image 1 of 3 Wii U GamePad LCD Display Replacement: step 16, image 2 of 3 Wii U GamePad LCD Display Replacement: step 16, image 3 of 3
      • Remove these two connectors to the motherboard with your fingers.
      Ask FixBot
    6. Wii U GamePad LCD Display Replacement: step 17, image 1 of 2 Wii U GamePad LCD Display Replacement: step 17, image 2 of 2
      • Remove the NFC communicator.
      • When removing the NFC communicator, be careful with the small connector on the back side.
      • Remove the small connector plug-in on the back.
      Ask FixBot
    7. Wii U GamePad LCD Display Replacement: step 18, image 1 of 3 Wii U GamePad LCD Display Replacement: step 18, image 2 of 3 Wii U GamePad LCD Display Replacement: step 18, image 3 of 3
      • Remove the remaining three 5.1 mm screws using the Phillips size #0 screwdriver.
      • Lift and remove the mother board.
      Ask FixBot
    1. Wii U GamePad LCD Display Replacement, LCD Display: step 19, image 1 of 2 Wii U GamePad LCD Display Replacement, LCD Display: step 19, image 2 of 2
      • Remove the four 5.1mm screws using Phillips size #0 screwdriver.
      • Pull the white and black cables away from the display case.
      Ask FixBot
    2. Wii U GamePad LCD Display Replacement: step 20, image 1 of 2 Wii U GamePad LCD Display Replacement: step 20, image 2 of 2
      • Lift and remove the grey display case with your fingers.
      Ask FixBot
    3. Wii U GamePad LCD Display Replacement: step 21, image 1 of 2 Wii U GamePad LCD Display Replacement: step 21, image 2 of 2
      • Gently with your fingers, press on the front of the display and it will lift up.
      • Remove the display with your fingers.
      Ask FixBot
88 other people completed this guide.
Valentina Cerruty
3,555 Reputation
7 Guides authored
USF Tampa, Team 1-6, Sullivan Spring 2016 Member of USF Tampa, Team 1-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G6
4 Members
84 Guides authored
20 Guide Comments
was really perfect to repair my device. Thank you very much for this help
Bernd Dietrich - Reply Share
In step 14 - what does the small gray ribbon do? The replacement LCD display that I got in the mail did not have it.
Stacey Hoggard - Reply Share
Its the touch screen cable. The screen I ordered did not come with one. I had to carefully remove it from my broken display and put it on the new one. Thankfully the touchscreen still works for me.
Terry Moenkhaus - Reply Share
Very happy with your manual! I've fixed it.
Paulus 68 - Reply Share
Mine did not come with the touch screen either.
Edwin Kahn - Reply Share
Past 24 Hours: 33
Past 7 Days: 209
Past 30 Days: 968
All Time: 120,651
