Wii Balance Board Front Cover Replacement
    1. Wii Balance Board Front Cover Replacement, Unscrewing the Foot Cover: step 1, image 1 of 1
      • Flip device upside-down so the plastic white board is facing the ground.
      • Locate the four feet in the corners of the Balance Board.
      • Unscrew the three 12.7 mm Phillips screws from each foot cover.
      Ask FixBot
    2. Wii Balance Board Front Cover Replacement, Removing the Foot Cover: step 2, image 1 of 1
      • Remove the gray plastic ring from the actual foot by lifting it up.
      Ask FixBot
    3. Wii Balance Board Front Cover Replacement, Removing the Foot: step 3, image 1 of 1
      • Separate the loose foot from the device by lifting it up.
      Ask FixBot
    4. Wii Balance Board Front Cover Replacement, Removing the Additional Feet: step 4, image 1 of 1
      • Repeat steps two and three on the remaining four feet.
      Ask FixBot
    1. Wii Balance Board Front Cover Replacement, Unscrewing the Back Cover: step 5, image 1 of 1
      • Unscrew the ten 12.7 mm Phillips #1 screws.
      Ask FixBot
    2. Wii Balance Board Front Cover Replacement, Removing the Back Cover: step 6, image 1 of 1
      • Lift off the gray back cover.
      Ask FixBot
    1. Wii Balance Board Front Cover Replacement, Battery Compartment: step 7, image 1 of 2 Wii Balance Board Front Cover Replacement, Battery Compartment: step 7, image 2 of 2
      • Locate the gray battery compartment.
      • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
      Ask FixBot
    2. Wii Balance Board Front Cover Replacement, Removing the Battery Case: step 8, image 1 of 1
      • Unscrew the two 6.35 mm Phillips #1 screws.
      • Slide the battery case out.
      Ask FixBot
    1. Wii Balance Board Front Cover Replacement, Unscrewing the Frame: step 9, image 1 of 1
      • Unscrew the four 12.7 mm #1 screws.
      Ask FixBot
    2. Wii Balance Board Front Cover Replacement, Removing the Frame: step 10, image 1 of 1
      • Lift the frame, circuit board, and power supply out of the front case. These components are all connected.
      Ask FixBot
Cory Olson
975 Reputation
4 Guides authored
Cal Poly, Team 13-8, Forte Fall 2014 Member of Cal Poly, Team 13-8, Forte Fall 2014
CPSU-FORTE-F14S13G8
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 33
All Time: 2,308
