Up to 20% off select tools
Wii Balance Board Frame Replacement
Views: 5.2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
25
Past 30 Days:
137
All Time:
5,164
Comments: 10
8 comments on steps, 2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 45 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
This guide will demonstrate how to replace the Power Supply inside the Wii Balance Board.
    1. Wii Balance Board Frame Replacement, Unscrewing the Foot Cover: step 1, image 1 of 1
      • Flip device upside-down so the plastic white board is facing the ground.
      • Locate the four feet in the corners of the Balance Board.
      • Unscrew the three 12.7 mm Phillips screws from each foot cover.
      Ask FixBot
    2. Wii Balance Board Frame Replacement, Removing the Foot Cover: step 2, image 1 of 1
      • Remove the gray plastic ring from the actual foot by lifting it up.
      Ask FixBot
    3. Wii Balance Board Frame Replacement, Removing the Foot: step 3, image 1 of 1
      • Separate the loose foot from the device by lifting it up.
      Ask FixBot
    4. Wii Balance Board Frame Replacement, Removing the Additional Feet: step 4, image 1 of 1
      • Repeat steps two and three on the remaining four feet.
      Ask FixBot
    1. Wii Balance Board Frame Replacement, Unscrewing the Back Cover: step 5, image 1 of 1
      • Unscrew the ten 12.7 mm Phillips #1 screws.
      Ask FixBot
    2. Wii Balance Board Frame Replacement, Removing the Back Cover: step 6, image 1 of 1
      • Lift off the gray back cover.
      Ask FixBot
    1. Wii Balance Board Frame Replacement, Battery Compartment: step 7, image 1 of 2 Wii Balance Board Frame Replacement, Battery Compartment: step 7, image 2 of 2
      • Locate the gray battery compartment.
      • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
      Ask FixBot
    2. Wii Balance Board Frame Replacement, Removing the Battery Case: step 8, image 1 of 1
      • Unscrew the two 6.35 mm Phillips #1 screws.
      • Slide the battery case out.
      Ask FixBot
    1. Wii Balance Board Frame Replacement, Unscrewing the Frame: step 9, image 1 of 1
      • Unscrew the four 12.7 mm #1 screws.
      Ask FixBot
    2. Wii Balance Board Frame Replacement, Removing the Frame: step 10, image 1 of 1
      • Lift the frame, circuit board, and power supply out of the front case. These components are all connected.
      Ask FixBot
    1. Wii Balance Board Frame Replacement, Removing the Power Supply: step 11, image 1 of 1
      • Lift out the power supply. It is not screwed in.
      Ask FixBot
Author
with
Cory Olson
975 Reputation
4 Guides authored
Cal Poly, Team 13-8, Forte Fall 2014 Member of Cal Poly, Team 13-8, Forte Fall 2014
CPSU-FORTE-F14S13G8
5 Members
60 Guides authored
2 Guide Comments
Top Anleitung, aber wo kann ich die Platine herbekommen? Danke!!!
Dominik - Reply Share
Hi, My batteries leaked over the UART_RX pin and I don't know how to fix it
Julián Rodríguez - Reply Share
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 137
All Time: 5,164
