Wii Balance Board Battery Case Replacement
  1. Wii Balance Board Battery Case Replacement, Unscrewing the Foot Cover: step 1, image 1 of 1
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
    Ask FixBot
  2. Wii Balance Board Battery Case Replacement, Removing the Foot Cover: step 2, image 1 of 1
    • Remove the gray plastic ring from the actual foot by lifting it up.
    Ask FixBot
  3. Wii Balance Board Battery Case Replacement, Removing the Foot: step 3, image 1 of 1
    • Separate the loose foot from the device by lifting it up.
    Ask FixBot
  4. Wii Balance Board Battery Case Replacement, Removing the Additional Feet: step 4, image 1 of 1
    • Repeat steps two and three on the remaining four feet.
    Ask FixBot
  5. Wii Balance Board Battery Case Replacement, Unscrewing the Back Cover: step 5, image 1 of 1
    • Unscrew the ten 12.7 mm Phillips #1 screws.
    Ask FixBot
  6. Wii Balance Board Battery Case Replacement, Removing the Back Cover: step 6, image 1 of 1
    • Lift off the gray back cover.
    Ask FixBot
  7. Wii Balance Board Battery Case Replacement, Battery Compartment: step 7, image 1 of 2 Wii Balance Board Battery Case Replacement, Battery Compartment: step 7, image 2 of 2
    • Locate the gray battery compartment.
    • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
    Ask FixBot
  8. Wii Balance Board Battery Case Replacement, Removing the Battery Case: step 8, image 1 of 1
    • Unscrew the two 6.35 mm Phillips #1 screws.
    • Slide the battery case out.
    Ask FixBot
20 other people completed this guide.
Michelle Reed
552 Reputation
1 Guide authored
Cal Poly, Team 13-8, Forte Fall 2014 Member of Cal Poly, Team 13-8, Forte Fall 2014
CPSU-FORTE-F14S13G8
5 Members
17 Guides authored
14 Guide Comments
I unscrewed everything, but were do i find a replacement battery compartent?
Olivia C - Reply Share
Then what do you do after you remove the battery case?
CRAIG WIKMAN - Reply Share
Is there a way to open the top of the board by sliding or lifting the top? I bought a gently used wii fit. The lady who sold it to me very quickly opened the top of the board from the centre seam to show me the instruction manual and I think hook up cables. I cannot, for the life of me figure out how she did it! Any ideas or technical wizardry you can share?
Frustrated in Canada!
Pam Murray - Reply Share
u rock - it totally worked
scottydecept - Reply Share
Why tell to remove all those parts and then there's no replacement battery board
Valerie Triplin - Reply Share
Past 24 Hours: 9
Past 7 Days: 43
Past 30 Days: 226
All Time: 48,363
