Up to 20% off select tools
Wii Balance Board Back Cover Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
97
All Time:
2,199
Comments: 3
3 comments on steps.
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
This guide will demonstrate how to replace the back cover of the Balance Board.
    1. Wii Balance Board Back Cover Replacement, Unscrewing the Foot Cover: step 1, image 1 of 1
      • Flip device upside-down so the plastic white board is facing the ground.
      • Locate the four feet in the corners of the Balance Board.
      • Unscrew the three 12.7 mm Phillips screws from each foot cover.
      Ask FixBot
    2. Wii Balance Board Back Cover Replacement, Removing the Foot Cover: step 2, image 1 of 1
      • Remove the gray plastic ring from the actual foot by lifting it up.
      Ask FixBot
    3. Wii Balance Board Back Cover Replacement, Removing the Foot: step 3, image 1 of 1
      • Separate the loose foot from the device by lifting it up.
      Ask FixBot
    4. Wii Balance Board Back Cover Replacement, Removing the Additional Feet: step 4, image 1 of 1
      • Repeat steps two and three on the remaining four feet.
      Ask FixBot
    1. Wii Balance Board Back Cover Replacement, Unscrewing the Back Cover: step 5, image 1 of 1
      • Unscrew the ten 12.7 mm Phillips #1 screws.
      Ask FixBot
    2. Wii Balance Board Back Cover Replacement, Removing the Back Cover: step 6, image 1 of 1
      • Lift off the gray back cover.
      Ask FixBot
Author
with
Cory Olson
975 Reputation
4 Guides authored
Cal Poly, Team 13-8, Forte Fall 2014 Member of Cal Poly, Team 13-8, Forte Fall 2014
CPSU-FORTE-F14S13G8
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 97
All Time: 2,199
