Wi-Fi Chipset why! WDi7SSD replacement
    1. Wi-Fi Chipset why! WDi7SSD replacement, why! WDi7SSD Opening procedure: step 1, image 1 of 3 Wi-Fi Chipset why! WDi7SSD replacement, why! WDi7SSD Opening procedure: step 1, image 2 of 3 Wi-Fi Chipset why! WDi7SSD replacement, why! WDi7SSD Opening procedure: step 1, image 3 of 3
      • Make sure the computer is disconnected from the power source.
      • Flip the computer over.
      • Remove the six screws with a 2 mm Allen key.
      • Carefully remove the back panel, as well the left and right panel.
      Ask FixBot
    2. Wi-Fi Chipset why! WDi7SSD replacement: step 2, image 1 of 1
      • Now flip up the base panel to which all components are attached.
      Ask FixBot
    1. Wi-Fi Chipset why! WDi7SSD replacement, Wi-Fi Chipset: step 3, image 1 of 2 Wi-Fi Chipset why! WDi7SSD replacement, Wi-Fi Chipset: step 3, image 2 of 2
      • Find your Wi-Fi / Bluetooth Chipset.
      • Loosen the two screws with the Phillips screwdriver.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 54
All Time: 279
