This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Why! V540TU BIOS Battery Replacement
    1. Why! V540TU BIOS Battery Replacement, Lower housing 1: step 1, image 1 of 3 Why! V540TU BIOS Battery Replacement, Lower housing 1: step 1, image 2 of 3 Why! V540TU BIOS Battery Replacement, Lower housing 1: step 1, image 3 of 3
      • Unscrew the screws circled in red.
      • Insert the opening pick into the gap and slide it all the way around.
      Ask FixBot
    2. Why! V540TU BIOS Battery Replacement, Lower housing 2: step 2, image 1 of 3 Why! V540TU BIOS Battery Replacement, Lower housing 2: step 2, image 2 of 3 Why! V540TU BIOS Battery Replacement, Lower housing 2: step 2, image 3 of 3
      • Unclip the housing at the corners.
      • Lift the cover.
      Ask FixBot
    1. Why! V540TU BIOS Battery Replacement, Battery cable: step 3, image 1 of 1
      • Unplug the cable.
      Ask FixBot
    1. Why! V540TU BIOS Battery Replacement, SSD: step 4, image 1 of 3 Why! V540TU BIOS Battery Replacement, SSD: step 4, image 2 of 3 Why! V540TU BIOS Battery Replacement, SSD: step 4, image 3 of 3
      • Unscrew the screw.
      • Lift the SSD and remove it.
      Ask FixBot
    1. Why! V540TU BIOS Battery Replacement, BIOS Battery: step 5, image 1 of 2 Why! V540TU BIOS Battery Replacement, BIOS Battery: step 5, image 2 of 2
      • Unplug the cable.
      • Peel off the battery.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 56
All Time: 164
