This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Why! NV41MZ Right Speaker Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
8
Past 30 Days:
44
All Time:
320
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide shows you how to replace the right speaker of a why! NV41MZ.
    1. Why! NV41MZ Right Speaker Replacement, Bottom Cover: step 1, image 1 of 3 Why! NV41MZ Right Speaker Replacement, Bottom Cover: step 1, image 2 of 3 Why! NV41MZ Right Speaker Replacement, Bottom Cover: step 1, image 3 of 3
      • Remove the 14 screws securing the bottom case to the laptop.
      • Unclip the case by sliding a plastic spudger into the slots in the case.
      • Remove the bottom case.
      Ask FixBot
    1. Why! NV41MZ Right Speaker Replacement, Remove the SSD: step 2, image 1 of 2 Why! NV41MZ Right Speaker Replacement, Remove the SSD: step 2, image 2 of 2
      • Remove the Phillips screw securing the SSD.
      • The SSD board will pop up slightly once the screw is removed. Lift it to relieve any tension and pull it straight out.
      Ask FixBot
    1. Why! NV41MZ Right Speaker Replacement, Battery: step 3, image 1 of 2 Why! NV41MZ Right Speaker Replacement, Battery: step 3, image 2 of 2
      • Remove the five Phillips screws securing the battery.
      • Unplug the cable connecting the battery to the motherboard.
      • Remove the battery.
      Ask FixBot
    1. Why! NV41MZ Right Speaker Replacement, Right Speaker: step 4, image 1 of 3 Why! NV41MZ Right Speaker Replacement, Right Speaker: step 4, image 2 of 3 Why! NV41MZ Right Speaker Replacement, Right Speaker: step 4, image 3 of 3
      • Remove the CMOS battery by carefully peeling it off.
      • Unscrew the 2 speaker screws.
      • Peel off the adhesive strip using an opening pick or spudger.
      Ask FixBot
    2. Why! NV41MZ Right Speaker Replacement, Remove the Speaker: step 5, image 1 of 1
      • Disconnect the speaker cable from the motherboard.
      • Remove the speaker.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
Jerry Wheeler is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 44
All Time: 320
