This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Introduction
This guide shows how to remove and replace the motherboard of a why! NV41MZ laptop after accessing it. Turn off and unplug the computer, then carefully release the cables and ribbon cables before lifting the motherboard.
Unscrew the 2 keyboard screws.
Insert an opening pick in the upper part of the keyboard.
Slide the pick along the upper edge of the keyboard.
Carefully flip the keyboard over to access the cables.
Flip up the retaining latches then pull the cables straight out from the connectors.
Remove the keyboard.
Remove the 14 screws securing the bottom case to the laptop.
Unclip the case by sliding a plastic spudger into the slots in the case.
Remove the bottom case.
Spread the retaining clips to release the RAM module. It will pop up slightly.
Pull the RAM module straight out to remove it.
Remove the Phillips screw securing the WiFi card.
Pull the card straight out from the connector.
Unclip the antenna wires from the card.
Remove the Phillips screw securing the SSD.
The SSD board will pop up slightly once the screw is removed. Lift it to relieve any tension and pull it straight out.
Remove the five Phillips screws securing the battery.
Unplug the cable connecting the battery to the motherboard.
Remove the battery.
Remove the two screws securing the right CPU fan to the case.
Remove the mounting tape.
Unplug the fan cable from the motherboard.
Remove the two Phillips screws securing the left CPU fan to the chassis.
Peel off the mounting tape.
Remove the five Phillips mounting screws securing the motherboard to the case.
Peel off the adhesive tape formerly covered by the RAM module.
Peel the tape from the WiFi card cables to keep them from getting in the way.
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
100%
Jerry Wheeler is helping us fix the world! Want to contribute?
Start translating ›
