Whirlpool WGD4800XQ Thermal Fuse Replacement
  1. Whirlpool WGD4800XQ Thermal Fuse Replacement, Thermal Fuse: step 1, image 1 of 1
    • Unplug the dryer from the power outlet.
    Ask FixBot
  2. Whirlpool WGD4800XQ Thermal Fuse Replacement: step 2, image 1 of 2 Whirlpool WGD4800XQ Thermal Fuse Replacement: step 2, image 2 of 2
    • Unscrew the backplate by rotating each screw counterclockwise with a ratchet and 8mm socket.
    • The screws are located around the edges of the backplate.
    • The backplate is a heavy object. Hold the backplate while removing the screws or get assistance. Dropping the backplate can cause injury or break the gas pipe.
    Ask FixBot
  3. Whirlpool WGD4800XQ Thermal Fuse Replacement: step 3, image 1 of 1
    • Lift the backplate off of the dryer.
    Ask FixBot
  4. Whirlpool WGD4800XQ Thermal Fuse Replacement: step 4, image 1 of 1
    • Pull out the blue terminal cables on the thermal fuse with a needle nose plier.
    • Keep track of what terminal fuse goes on top and bottom.
    Ask FixBot
  5. Whirlpool WGD4800XQ Thermal Fuse Replacement: step 5, image 1 of 1
    • Remove the screw from the thermal fuse with the ratchet and 8mm socket.
    Ask FixBot
  6. Whirlpool WGD4800XQ Thermal Fuse Replacement: step 6, image 1 of 1
    • Place the new thermal fuse and secure the screw with the ratchet and 8 mm socket.
    Ask FixBot
  7. Whirlpool WGD4800XQ Thermal Fuse Replacement: step 7, image 1 of 1
    • Insert the blue terminal cables to the thermal fuse with a needle nose plier.
    Ask FixBot
  8. Whirlpool WGD4800XQ Thermal Fuse Replacement: step 8, image 1 of 2 Whirlpool WGD4800XQ Thermal Fuse Replacement: step 8, image 2 of 2
    • Put the back plate on the dryer.
    • If possible, have someone hold it up to align all the holes on the backplate and dryer while you use the ratchet and 8 mm socket to replace the screws.
    Ask FixBot
  9. Whirlpool WGD4800XQ Thermal Fuse Replacement: step 9, image 1 of 1
    • Connect the dryer to the power outlet.
    Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 102
All Time: 2,192
