Whirlpool Refrigerator Water Inlet Valve Replacement
Views: 17K
View statistics:
Past 24 Hours:
6
Past 7 Days:
62
Past 30 Days:
384
All Time:
16,616
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the inlet valve assembly in your Whirlpool Refrigerator.
The inlet valve assembly is an electrically-controlled mechanical valve that opens to supply water to the dispenser and icemaker. If your refrigerator isn't making ice or dispensing water properly, your inlet valve assembly might be broken.
This guide will work for most Whirlpool refrigerators. This guide is written with a model WRS315SDHW refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
    1. Whirlpool Refrigerator Water Inlet Valve Replacement, Safety precautions: step 1, image 1 of 1
      • Before you begin your repair, perform the following:
      • Turn off your main water supply
      • Unplug your device
      Ask FixBot
    1. Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: step 2, image 1 of 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: step 2, image 2 of 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: step 2, image 3 of 3
      • Remove the screw(s) securing the rear panel.
      • Loosen the screw securing the water hose enough for the rear panel to freely move.
      Ask FixBot
    2. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: step 3, image 1 of 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: step 3, image 2 of 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: step 3, image 3 of 3
      • Pull the rear panel off the chassis to remove it.
      Ask FixBot
    1. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: step 4, image 1 of 2 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: step 4, image 2 of 2
      • Use needle nose pliers, or your fingers, to remove the plastic clip on the inlet valve assembly.
      Ask FixBot
    2. Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: step 5, image 1 of 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: step 5, image 2 of 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: step 5, image 3 of 3
      • Push the plastic ring above the front water hose to release its clips.
      • As you push the ring, pull the water hose downward to disconnect it.
      • Repeat the disconnection procedure for the other water hose on the inlet valve assembly.
      Ask FixBot
    3. Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the inlet valve assembly: step 6, image 1 of 1
      • Remove the screw(s) securing the inlet valve assembly.
      Ask FixBot
    4. Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: step 7, image 1 of 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: step 7, image 2 of 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: step 7, image 3 of 3
      • Pull the inlet valve assembly off its slot in the chassis and rest it on the floor.
      Ask FixBot
    5. Whirlpool Refrigerator Water Inlet Valve Replacement: step 8, image 1 of 2 Whirlpool Refrigerator Water Inlet Valve Replacement: step 8, image 2 of 2
      • Place a clean and dry rag under the inlet valve assembly before continuing.
      Ask FixBot
    6. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: step 9, image 1 of 2 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: step 9, image 2 of 2
      • Use needle nose pliers, or your hands, to pull the clip off the rear water hose.
      Ask FixBot
    7. Whirlpool Refrigerator Water Inlet Valve Replacement: step 10, image 1 of 3 Whirlpool Refrigerator Water Inlet Valve Replacement: step 10, image 2 of 3 Whirlpool Refrigerator Water Inlet Valve Replacement: step 10, image 3 of 3
      • Push the yellow plastic ring above the rear water hose to release its clips.
      • As you push the ring, pull the water hose away from the inlet valve assembly to disconnect it.
      Ask FixBot
    8. Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: step 11, image 1 of 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: step 11, image 2 of 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: step 11, image 3 of 3
      • Use a flathead screwdriver, or a similar tool, to disconnect any wire connectors attached to the inlet valve assembly.
      Ask FixBot
    9. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the inlet valve assembly: step 12, image 1 of 1
      • Remove the inlet valve assembly from the chassis.
      Ask FixBot
    10. Whirlpool Refrigerator Water Inlet Valve Replacement, Meter the inlet valve assembly: step 13, image 1 of 1
      • If you own a multimeter, you can test your inlet valve assembly's resistance.
      • A range between 500–1.5 kΩ is acceptable.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,990 Reputation
88 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 62
Past 30 Days: 384
All Time: 16,616
