Whirlpool Refrigerator Start Relay Assembly Replacement
Views: 18K
View statistics:
Past 24 Hours:
10
Past 7 Days:
105
Past 30 Days:
450
All Time:
18,048
Comments: 3
3 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the start relay assembly or compressor start device in your Whirlpool Refrigerator.
The start relay is a combination of the start relay, the overload relay, and the start capacitor, which are responsible for protecting your compressor's circuit. If the fans are running and your compressor won’t start, or if you hear a clicking sound from the unit, your start relay assembly might be broken.
This guide will work for most Whirlpool refrigerators. This guide is written with a model WRS315SDHW refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
Parts
Tools
    1. Whirlpool Refrigerator Start Relay Assembly Replacement, Safety precautions: step 1, image 1 of 1
      • Before you begin your repair, perform the following:
      • Turn off your main water supply
      • Unplug your device
      Ask FixBot
    1. Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: step 2, image 1 of 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: step 2, image 2 of 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: step 2, image 3 of 3
      • Remove the screw(s) securing the rear panel.
      • Loosen the screw securing the water hose enough for the rear panel to freely move.
      Ask FixBot
    2. Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: step 3, image 1 of 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: step 3, image 2 of 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: step 3, image 3 of 3
      • Pull the rear panel off the chassis to remove it.
      Ask FixBot
    1. Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: step 4, image 1 of 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: step 4, image 2 of 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: step 4, image 3 of 3
      • Use a flathead screwdriver, or a similar tool, to disconnect any connectors attached to the start relay assembly.
      Ask FixBot
    2. Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: step 5, image 1 of 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: step 5, image 2 of 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: step 5, image 3 of 3
      • Pull the metal clip out its hole in the top of the start relay assembly.
      • Rest the clip next to the assembly.
      Ask FixBot
    3. Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: step 6, image 1 of 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: step 6, image 2 of 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: step 6, image 3 of 3
      • Pull the start relay assembly straight off its prongs in the chassis.
      • Remove the start relay assembly.
      • The assembly consists of the run capacitor, start relay, and overload relay.
      Ask FixBot
    4. Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: step 7, image 1 of 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: step 7, image 2 of 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: step 7, image 3 of 3
      • If you own a multimeter, you can test the start relay and overload relay's resistance.
      • A range between 0–1 Ω for the overload relay, and 0–5 Ω for the start relay is acceptable.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
5 other people completed this guide.
nicO
15,990 Reputation
88 Guides authored
3 Guide Comments
Is it universal part
dyannatorres@yahoo.com - Reply Share
While the parts are similar, there are differences for fridges. If you can find your refrigerator model number, you'll be able to search online for the correct start relay for your specific model. Good luck!
nicO - Reply Share
Last part is not clear about where to put multimeter probes for testing each component. It makes the whole exercise useless.
Shafeeq Qaiser - Reply Share
Past 24 Hours: 10
Past 7 Days: 105
Past 30 Days: 450
All Time: 18,048
