Whirlpool Refrigerator Ice Maker Wiring Repair
Video Guide
This guide was transcribed from a YouTube video.
      • Press the control panel to verify water dispenses but ice and certain buttons do not respond.
      • This symptom indicates the door harness test in this guide applies to your refrigerator.
      Ask FixBot
      • Open the freezer door and locate the black wire trunk beneath the hinge between the freezer and refrigerator doors.
      • If the loom shows cracked insulation or exposed conductors the harness is likely at fault.
      Ask FixBot
      • Pull the unit forward and inspect the wire loom at the rear cabinet for identical damage.
      • The repair method is the same if the break is behind the refrigerator instead of the door hinge.
      Ask FixBot
      • Remove frozen food and swing both doors fully open for clearance.
      • Extract the two downward-facing Phillips screws securing the lower hinge cover.
      • Flex the plastic cover edges inward and pull the cover off to expose the harness block.
      Ask FixBot
      • Evaluate workspace and decide whether to lift the door off the bottom hinge or leave it installed.
      • Door removal offers more room but is not mandatory for this splice repair.
      Ask FixBot
      • Peel back the black rubber sleeve from the harness without cutting the wires.
      • Use side snips to remove the grey plastic edge that previously sliced the conductors.
      • Open and close the door several times to ensure the trimmed area no longer contacts the harness.
      Ask FixBot
      • Arrange a heat gun, wire strippers, side cutters, a helping-hands stand, and heat-shrink solder-seal connectors.
      • Select blue connectors for 14 AWG leads and red connectors for 18-22 AWG wires.
      • Cut 3-6 inch lengths of 14 AWG and 18 AWG wire to use as strain-relief extensions.
      Ask FixBot
      • Cut each broken conductor back to clean copper ends.
      • Slide the correct connector onto one side before removing about ½ inch of insulation from both ends.
      • Measure and insert a matching gauge extension wire to relieve strain on the hinge area.
      Ask FixBot
      • Cross the stripped ends near the jackets and wrap the right lead around the left one-third of its length.
      • Wrap the left lead around the right to complete a western union splice.
      • Pull firmly on both sides to confirm the splice will not separate.
      Ask FixBot
      • Center the solder band of the connector over the splice.
      • Apply consistent hot air, focusing on the solder until it flows and the tubing fully shrinks.
      • Shield flooring, cabinetry and adjacent wires from heat to prevent damage.
      Ask FixBot
      • Repeat the splice and heat process for every damaged wire, matching connector color to wire size.
      • Use the helping hands stand to hold joints steady so both hands remain free for the heat gun.
      • Re-wrap any joint that loosens when tugged before applying heat.
      Ask FixBot
      • Slide continuous heat-shrink tubing or a split sleeve over the repaired bundle for abrasion protection.
      Ask FixBot
      • Refit the hinge cover, reinstall the two screws and close the doors.
      • Restore power and operate the dispenser to confirm the auger turns and ice production resumes.
      Ask FixBot
      • If the icemaker still fails, remove the control board cover and inspect both PCB sides for burn marks or blown components.
      • Replace the board only when visible damage confirms a short caused by the broken harness.
      Ask FixBot
After the splice repair, cycle the freezer door several times and confirm the ice maker resumes normal operation without stressing the harness. Repair didn't go as planned? Ask our Answers community for help.
Ben Schlichter
7,128 Reputation
224 Guides authored
0 Guide Comments
Past 24 Hours: 14
Past 7 Days: 53
Past 30 Days: 267
All Time: 1,272
