Whirlpool Refrigerator Freezer Thermistor Replacement
    1. Whirlpool Refrigerator Freezer Thermistor Replacement, Safety precautions: step 1, image 1 of 1
      • Before you begin your repair, perform the following:
      • Turn off your main water supply
      • Unplug your device
      Ask FixBot
    1. Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: step 2, image 1 of 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: step 2, image 2 of 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: step 2, image 3 of 3
      • Depending on your repair, open one or both doors.
      Ask FixBot
    1. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the drawers: step 3, image 1 of 2 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the drawers: step 3, image 2 of 2
      • Remove the drawers and shelves from the freezer section.
      Ask FixBot
    2. Whirlpool Refrigerator Freezer Thermistor Replacement: step 4, image 1 of 2 Whirlpool Refrigerator Freezer Thermistor Replacement: step 4, image 2 of 2
      • Remove the screw(s) securing the evaporator cover.
      Ask FixBot
    3. Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: step 5, image 1 of 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: step 5, image 2 of 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: step 5, image 3 of 3
      • Lift the bottom of the evaporator cover up and over its lip in the chassis.
      • Pull the cover toward yourself to release its top clips.
      Ask FixBot
    4. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: step 6, image 1 of 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: step 6, image 2 of 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: step 6, image 3 of 3
      • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
      • Remove the evaporator cover.
      Ask FixBot
    1. Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: step 7, image 1 of 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: step 7, image 2 of 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: step 7, image 3 of 3
      • Use a spudger to push the tip of the thermistor through its slot in the wire harness.
      Ask FixBot
    2. Whirlpool Refrigerator Freezer Thermistor Replacement, Disconnect the thermistor: step 8, image 1 of 2 Whirlpool Refrigerator Freezer Thermistor Replacement, Disconnect the thermistor: step 8, image 2 of 2
      • Disconnect any connectors attached to the thermistor.
      Ask FixBot
    3. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the thermistor: step 9, image 1 of 1
      • Remove the thermistor.
      Ask FixBot
    4. Whirlpool Refrigerator Freezer Thermistor Replacement, Meter the thermistor: step 10, image 1 of 1
      • If you own a multimeter, you can test your thermistor's resistance.
      • A range between 2-220KΩ is acceptable. Check the specifications for your specific thermistor since there is such a large variance, and make sure you test at the appropriate temperature.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
2 other people completed this guide.
nicO
15,990 Reputation
89 Guides authored
1 Guide Comment
Does anyone know the thermistor part number it’s not listed on the parts breakdown
Tony - Reply Share
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 177
All Time: 5,161
