Whirlpool Refrigerator Freezer Door Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
7
Past 7 Days:
37
Past 30 Days:
181
All Time:
3,251
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to remove or replace the freezer door in your Whirlpool Refrigerator.
This guide will work for most Whirlpool refrigerators. This guide is written with a model WRS315SDHW refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
Tools
    1. Whirlpool Refrigerator Freezer Door Replacement, Safety precautions: step 1, image 1 of 1
      • Before you begin your repair, perform the following:
      • Turn off your main water supply
      • Unplug your device
      Ask FixBot
    1. Whirlpool Refrigerator Freezer Door Replacement, Open the doors: step 2, image 1 of 3 Whirlpool Refrigerator Freezer Door Replacement, Open the doors: step 2, image 2 of 3 Whirlpool Refrigerator Freezer Door Replacement, Open the doors: step 2, image 3 of 3
      • Depending on your repair, open one or both doors.
      Ask FixBot
    1. Whirlpool Refrigerator Freezer Door Replacement, Unfasten the front panel: step 3, image 1 of 3 Whirlpool Refrigerator Freezer Door Replacement, Unfasten the front panel: step 3, image 2 of 3 Whirlpool Refrigerator Freezer Door Replacement, Unfasten the front panel: step 3, image 3 of 3
      • Remove the screw(s) securing the front panel.
      Ask FixBot
    2. Whirlpool Refrigerator Freezer Door Replacement, Remove the front panel: step 4, image 1 of 3 Whirlpool Refrigerator Freezer Door Replacement, Remove the front panel: step 4, image 2 of 3 Whirlpool Refrigerator Freezer Door Replacement, Remove the front panel: step 4, image 3 of 3
      • Pull the front panel straight off the chassis and remove it.
      • You may have to slightly open the water filter door to remove the front panel completely.
      Ask FixBot
    1. Whirlpool Refrigerator Freezer Door Replacement, Unfasten the door connections: step 5, image 1 of 2 Whirlpool Refrigerator Freezer Door Replacement, Unfasten the door connections: step 5, image 2 of 2
      • Remove the screw(s) securing the freezer door wiring harness.
      • Remove the screw(s) securing the freezer door water hose.
      Ask FixBot
    2. Whirlpool Refrigerator Freezer Door Replacement, Reposition the wiring harness: step 6, image 1 of 2 Whirlpool Refrigerator Freezer Door Replacement, Reposition the wiring harness: step 6, image 2 of 2
      • Pull the wiring harness out of its slot in the chassis to access its connectors.
      Ask FixBot
    3. Whirlpool Refrigerator Freezer Door Replacement, Disconnect the wiring harness: step 7, image 1 of 3 Whirlpool Refrigerator Freezer Door Replacement, Disconnect the wiring harness: step 7, image 2 of 3 Whirlpool Refrigerator Freezer Door Replacement, Disconnect the wiring harness: step 7, image 3 of 3
      • Disconnect any connectors attached to the door wiring harness.
      Ask FixBot
    4. Whirlpool Refrigerator Freezer Door Replacement: step 8, image 1 of 1
      • Place a clean cloth under the water hose before continuing.
      Ask FixBot
    5. Whirlpool Refrigerator Freezer Door Replacement: step 9, image 1 of 2 Whirlpool Refrigerator Freezer Door Replacement: step 9, image 2 of 2
      • Pull the plastic clip off the freezer door water hose.
      Ask FixBot
    6. Whirlpool Refrigerator Freezer Door Replacement, Disconnect the water hose: step 10, image 1 of 3 Whirlpool Refrigerator Freezer Door Replacement, Disconnect the water hose: step 10, image 2 of 3 Whirlpool Refrigerator Freezer Door Replacement, Disconnect the water hose: step 10, image 3 of 3
      • Use one hand to compress the blue plastic ring into the green section of the hose.
      • Use the other hand to pull the water tube out of its slot.
      Ask FixBot
    7. Whirlpool Refrigerator Freezer Door Replacement, Unfasten the freezer door: step 11, image 1 of 2 Whirlpool Refrigerator Freezer Door Replacement, Unfasten the freezer door: step 11, image 2 of 2
      • Depending on your device, you may have a plastic cover on the hinge. Remove it before continuing.
      • Hold the door while performing the next two steps to avoid the door from accidentally falling.
      • Remove the screw(s) securing the freezer door.
      • Some devices may have screws solely for alignment. You don't need to remove these.
      Ask FixBot
    8. Whirlpool Refrigerator Freezer Door Replacement, Remove the door hinge: step 12, image 1 of 3 Whirlpool Refrigerator Freezer Door Replacement, Remove the door hinge: step 12, image 2 of 3 Whirlpool Refrigerator Freezer Door Replacement, Remove the door hinge: step 12, image 3 of 3
      • Pull the door hinge straight up to separate its alignment pins from the chassis.
      • Remove the door hinge.
      Ask FixBot
    9. Whirlpool Refrigerator Freezer Door Replacement, Reposition the cables: step 13, image 1 of 3 Whirlpool Refrigerator Freezer Door Replacement, Reposition the cables: step 13, image 2 of 3 Whirlpool Refrigerator Freezer Door Replacement, Reposition the cables: step 13, image 3 of 3
      • Pull the freezer door straight up to disconnect it from the chassis.
      • Thread the cables through their slot in the chassis.
      • You may need to thread them individually.
      Ask FixBot
    10. Whirlpool Refrigerator Freezer Door Replacement, Remove the door: step 14, image 1 of 2 Whirlpool Refrigerator Freezer Door Replacement, Remove the door: step 14, image 2 of 2
      • You're now left with the freezer door.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,990 Reputation
88 Guides authored
1 Guide Comment
There is a pending class action suit about this defect: https://chimicles.com/whirlpool-refriger...
Barbara Hoover - Reply Share
Past 24 Hours: 7
Past 7 Days: 37
Past 30 Days: 181
All Time: 3,251
