Whirlpool Refrigerator Defrost Heater Replacement
Views: 7.8K
View statistics:
Past 24 Hours:
10
Past 7 Days:
71
Past 30 Days:
298
All Time:
7,823
Comments: 1
1 comment on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the defrost heater in your Whirlpool Refrigerator.
The defrost heater melts frost off the evaporator fins. If your freezer is perpetually frosty, then the defrost heater might be broken.
This guide will work for most Whirlpool refrigerators. This guide is written with a model WRS315SDHW refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
Tools
    1. Whirlpool Refrigerator Defrost Heater Replacement, Safety precautions: step 1, image 1 of 1
      • Before you begin your repair, perform the following:
      • Turn off your main water supply
      • Unplug your device
      Ask FixBot
    1. Whirlpool Refrigerator Defrost Heater Replacement, Open the doors: step 2, image 1 of 3 Whirlpool Refrigerator Defrost Heater Replacement, Open the doors: step 2, image 2 of 3 Whirlpool Refrigerator Defrost Heater Replacement, Open the doors: step 2, image 3 of 3
      • Depending on your repair, open one or both doors.
      Ask FixBot
    1. Whirlpool Refrigerator Defrost Heater Replacement, Remove the drawers: step 3, image 1 of 2 Whirlpool Refrigerator Defrost Heater Replacement, Remove the drawers: step 3, image 2 of 2
      • Remove the drawers and shelves from the freezer section.
      Ask FixBot
    2. Whirlpool Refrigerator Defrost Heater Replacement: step 4, image 1 of 2 Whirlpool Refrigerator Defrost Heater Replacement: step 4, image 2 of 2
      • Remove the screw(s) securing the evaporator cover.
      Ask FixBot
    3. Whirlpool Refrigerator Defrost Heater Replacement, Unclip the evaporator cover: step 5, image 1 of 3 Whirlpool Refrigerator Defrost Heater Replacement, Unclip the evaporator cover: step 5, image 2 of 3 Whirlpool Refrigerator Defrost Heater Replacement, Unclip the evaporator cover: step 5, image 3 of 3
      • Lift the bottom of the evaporator cover up and over its lip in the chassis.
      • Pull the cover toward yourself to release its top clips.
      Ask FixBot
    4. Whirlpool Refrigerator Defrost Heater Replacement, Remove the evaporator cover: step 6, image 1 of 3 Whirlpool Refrigerator Defrost Heater Replacement, Remove the evaporator cover: step 6, image 2 of 3 Whirlpool Refrigerator Defrost Heater Replacement, Remove the evaporator cover: step 6, image 3 of 3
      • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
      • Remove the evaporator cover.
      Ask FixBot
    1. Whirlpool Refrigerator Defrost Heater Replacement, Disconnect the defrost heater: step 7, image 1 of 3 Whirlpool Refrigerator Defrost Heater Replacement, Disconnect the defrost heater: step 7, image 2 of 3 Whirlpool Refrigerator Defrost Heater Replacement, Disconnect the defrost heater: step 7, image 3 of 3
      • Disconnect the connector(s) attached to the defrost heater.
      Ask FixBot
    2. Whirlpool Refrigerator Defrost Heater Replacement, Reposition the cable: step 8, image 1 of 3 Whirlpool Refrigerator Defrost Heater Replacement, Reposition the cable: step 8, image 2 of 3 Whirlpool Refrigerator Defrost Heater Replacement, Reposition the cable: step 8, image 3 of 3
      • Pull the defrost heater cable out from behind the evaporator.
      Ask FixBot
    3. Whirlpool Refrigerator Defrost Heater Replacement, Unfasten the defrost heater bracket: step 9, image 1 of 1
      • Remove the screw(s) securing the defrost heater bracket.
      Ask FixBot
    4. Whirlpool Refrigerator Defrost Heater Replacement, Release the defrost heater bracket: step 10, image 1 of 2 Whirlpool Refrigerator Defrost Heater Replacement, Release the defrost heater bracket: step 10, image 2 of 2
      • Pull the defrost heater bracket up to release it from its slot in the chassis.
      Ask FixBot
    5. Whirlpool Refrigerator Defrost Heater Replacement, Remove the defrost heater: step 11, image 1 of 3 Whirlpool Refrigerator Defrost Heater Replacement, Remove the defrost heater: step 11, image 2 of 3 Whirlpool Refrigerator Defrost Heater Replacement, Remove the defrost heater: step 11, image 3 of 3
      • Slide the defrost heater from under the evaporator.
      • You may need to pull one end at a time until it's completely removed.
      Ask FixBot
    6. Whirlpool Refrigerator Defrost Heater Replacement, Only the defrost heater remains: step 12, image 1 of 1
      • You're now left with the defrost heater.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
5 other people completed this guide.
nicO
15,990 Reputation
88 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 71
Past 30 Days: 298
All Time: 7,823
