Whirlpool Dryer Idler Arm Replacement
  1. Whirlpool Dryer Idler Arm Replacement, Safety Precautions: step 1, image 1 of 1
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
    Ask FixBot
  2. Whirlpool Dryer Idler Arm Replacement, Unfasten the top panel: step 2, image 1 of 3 Whirlpool Dryer Idler Arm Replacement, Unfasten the top panel: step 2, image 2 of 3 Whirlpool Dryer Idler Arm Replacement, Unfasten the top panel: step 2, image 3 of 3
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a nut driver to remove the screws securing the top panel to the rear panel bracket.
    Ask FixBot
  3. Whirlpool Dryer Idler Arm Replacement, Remove the top panel: step 3, image 1 of 2 Whirlpool Dryer Idler Arm Replacement, Remove the top panel: step 3, image 2 of 2
    • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
    Ask FixBot
  4. Whirlpool Dryer Idler Arm Replacement: step 4, image 1 of 2 Whirlpool Dryer Idler Arm Replacement: step 4, image 2 of 2
    • Lift the top panel upward to separate it from the chassis.
    • Remove the top panel from the machine.
    Ask FixBot
  5. Whirlpool Dryer Idler Arm Replacement, Unfasten the cover plate: step 5, image 1 of 1
    • Remove the cover plate screw.
    Ask FixBot
  6. Whirlpool Dryer Idler Arm Replacement, Remove the cover plate: step 6, image 1 of 3 Whirlpool Dryer Idler Arm Replacement, Remove the cover plate: step 6, image 2 of 3 Whirlpool Dryer Idler Arm Replacement, Remove the cover plate: step 6, image 3 of 3
    • Remove the cover plate.
    Ask FixBot
  7. Whirlpool Dryer Idler Arm Replacement, Disconnect the cord: step 7, image 1 of 1
    • Remove the screws securing the cord cables.
    • Mark the cables with a permanent marker if needed and take a picture or draw a diagram.
    Ask FixBot
  8. Whirlpool Dryer Idler Arm Replacement, Remove the cord: step 8, image 1 of 3 Whirlpool Dryer Idler Arm Replacement, Remove the cord: step 8, image 2 of 3 Whirlpool Dryer Idler Arm Replacement, Remove the cord: step 8, image 3 of 3
    • Pull the cord carefully down through the round hole.
    • Make sure you replace the connections correctly when you reassemble.
    Ask FixBot
  9. Whirlpool Dryer Idler Arm Replacement, Unfasten the cord terminal block: step 9, image 1 of 1
    • Remove the green ground screw.
    • Remove the cord terminal block screws.
    Ask FixBot
  10. Whirlpool Dryer Idler Arm Replacement, Move the cord terminal block: step 10, image 1 of 3 Whirlpool Dryer Idler Arm Replacement, Move the cord terminal block: step 10, image 2 of 3 Whirlpool Dryer Idler Arm Replacement, Move the cord terminal block: step 10, image 3 of 3
    • Move the cord terminal block behind the rear panel.
    Ask FixBot
  11. Whirlpool Dryer Idler Arm Replacement, Unfasten the rear panel: step 11, image 1 of 2 Whirlpool Dryer Idler Arm Replacement, Unfasten the rear panel: step 11, image 2 of 2
    FixMat
    $36.95
    Buy
    • Remove the rear panel screws.
    Ask FixBot
  12. Whirlpool Dryer Idler Arm Replacement: step 12, image 1 of 2 Whirlpool Dryer Idler Arm Replacement: step 12, image 2 of 2
    • Remove the screw holding the main board bracket to the chassis.
    • Remove the screws from the top rear of the machine.
    Ask FixBot
  13. Whirlpool Dryer Idler Arm Replacement, Remove the rear panel: step 13, image 1 of 3 Whirlpool Dryer Idler Arm Replacement, Remove the rear panel: step 13, image 2 of 3 Whirlpool Dryer Idler Arm Replacement, Remove the rear panel: step 13, image 3 of 3
    • Put on gloves before continuing, as the rear panel is sharp.
    • Lift the panel about 1/2 inch and tilt it to the rear to release it from the vent pipe.
    • Slide the panel off the vent pipe and remove it.
    Ask FixBot
  14. Whirlpool Dryer Idler Arm Replacement, Reassembly information: step 14, image 1 of 2 Whirlpool Dryer Idler Arm Replacement, Reassembly information: step 14, image 2 of 2
    • During reassembly, perform the following:
    • Make sure that the vent pipe is fitted into the collar on the panel.
    • Make sure the tabs at the bottom are aligned to the bottom rim of the chassis.
    • Position the panel so its screw holes match with the chassis.
    Ask FixBot
  15. Whirlpool Dryer Idler Arm Replacement, Unfasten the idler arm: step 15, image 1 of 2 Whirlpool Dryer Idler Arm Replacement, Unfasten the idler arm: step 15, image 2 of 2
    • Remove the bolt securing the idler arm to the motor frame.
    Ask FixBot
  16. Whirlpool Dryer Idler Arm Replacement, Remove the idler arm: step 16, image 1 of 3 Whirlpool Dryer Idler Arm Replacement, Remove the idler arm: step 16, image 2 of 3 Whirlpool Dryer Idler Arm Replacement, Remove the idler arm: step 16, image 3 of 3
    • Move the idler arm toward the side of the dryer to unhook the idler arm tension spring from the arm.
    • Remove the idler arm.
    • During reassembly, be sure to reattach the spring before securing the arm.
    Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
40,113 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
123 Members
27,624 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 113
All Time: 1,934
