Whirlpool Dryer Drum Light Replacement
    1. Whirlpool Dryer Drum Light Replacement, Safety Precautions: step 1, image 1 of 1
      • Before you begin your repair, unplug your dryer.
      • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
      Ask FixBot
    1. Whirlpool Dryer Drum Light Replacement, Unfasten the top panel: step 2, image 1 of 3 Whirlpool Dryer Drum Light Replacement, Unfasten the top panel: step 2, image 2 of 3 Whirlpool Dryer Drum Light Replacement, Unfasten the top panel: step 2, image 3 of 3
      Tool used on this step:
      FixMat
      $36.95
      Buy
      • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
      • Use a nut driver to remove the screws securing the top panel to the rear panel bracket.
      Ask FixBot
    2. Whirlpool Dryer Drum Light Replacement, Remove the top panel: step 3, image 1 of 2 Whirlpool Dryer Drum Light Replacement, Remove the top panel: step 3, image 2 of 2
      • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
      Ask FixBot
    3. Whirlpool Dryer Drum Light Replacement: step 4, image 1 of 2 Whirlpool Dryer Drum Light Replacement: step 4, image 2 of 2
      • Lift the top panel upward to separate it from the chassis.
      • Remove the top panel from the machine.
      Ask FixBot
    1. Whirlpool Dryer Drum Light Replacement, Disconnect the control panel: step 5, image 1 of 2 Whirlpool Dryer Drum Light Replacement, Disconnect the control panel: step 5, image 2 of 2
      • Disconnect the control panel cable from the main board.
      Ask FixBot
    2. Whirlpool Dryer Drum Light Replacement: step 6, image 1 of 2 Whirlpool Dryer Drum Light Replacement: step 6, image 2 of 2
      • Disconnect the drum light connector.
      Ask FixBot
    3. Whirlpool Dryer Drum Light Replacement, Unfasten the control panel: step 7, image 1 of 2 Whirlpool Dryer Drum Light Replacement, Unfasten the control panel: step 7, image 2 of 2
      • Remove the screws securing the control panel.
      Ask FixBot
    4. Whirlpool Dryer Drum Light Replacement, Remove the control panel: step 8, image 1 of 3 Whirlpool Dryer Drum Light Replacement, Remove the control panel: step 8, image 2 of 3 Whirlpool Dryer Drum Light Replacement, Remove the control panel: step 8, image 3 of 3
      • Lift the control panel up and tilt it away from the chassis to remove it.
      • Make sure to thread the cable through the hole in the chassis.
      • During reassembly, thread the cable through its proper hole before reinstalling the control panel.
      Ask FixBot
    1. Whirlpool Dryer Drum Light Replacement, Disconnect the door switch: step 9, image 1 of 3 Whirlpool Dryer Drum Light Replacement, Disconnect the door switch: step 9, image 2 of 3 Whirlpool Dryer Drum Light Replacement, Disconnect the door switch: step 9, image 3 of 3
      • Use a small flat blade screwdriver or a spudger to unlatch both sides of the door switch connector.
      • Unplug the connector.
      Ask FixBot
    2. Whirlpool Dryer Drum Light Replacement, Unfasten the front panel: step 10, image 1 of 2 Whirlpool Dryer Drum Light Replacement, Unfasten the front panel: step 10, image 2 of 2
      • Remove the upper front panel sheet metal screws.
      • Tilt the machine backwards and prop it securely, or have a friend hold it.
      • Remove the sheet metal screws on the bottom edge of the panel.
      Ask FixBot
    3. Whirlpool Dryer Drum Light Replacement: step 11, image 1 of 1
      • Remove the screws inside the door area below the drum opening.
      Ask FixBot
    4. Whirlpool Dryer Drum Light Replacement, Remove the front panel: step 12, image 1 of 3 Whirlpool Dryer Drum Light Replacement, Remove the front panel: step 12, image 2 of 3 Whirlpool Dryer Drum Light Replacement, Remove the front panel: step 12, image 3 of 3
      • The panel is heavy and awkward. You may want to have a friend help you with this step.
      • Pull the bottom of the panel away from the chassis about two to three inches.
      • Lift the front panel off the small tabs on the chassis near the top of the panel and remove it.
      • Make sure you don't snag the door switch wire harness as you remove the panel.
      Ask FixBot
    1. Whirlpool Dryer Drum Light Replacement, Remove the drum light: step 13, image 1 of 3 Whirlpool Dryer Drum Light Replacement, Remove the drum light: step 13, image 2 of 3 Whirlpool Dryer Drum Light Replacement, Remove the drum light: step 13, image 3 of 3
      • Release the drum light module by pressing in on the tabs on the side of the module.
      • Push the module through the mounting hole in the front bulkhead and into the drum.
      • Feed the wiring harness through the mounting hole and remove the module and harness from the dryer.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
40,590 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 73
All Time: 1,056
