Video Guide
This guide was transcribed from a YouTube video.
Introduction
Go to step 1 ↓If a Whirlpool Cabrio washer won’t start, won’t turn on, or only beeps when you press Start, the user interface board can be the cause. This guide shows how to enter diagnostic mode, check for error codes (especially F6E2), remove the interface board, clean its contacts, and protect it with conformal coating to help prevent future moisture damage.
Step 1 Prepare the washer safely
Pull the washer out far enough to work behind it, but keep it close enough to use the wall as a support later.
Step 2 Remove the rear screws
Use a 1/4" nut driver to remove the three screws on the back of the washer.
Set the screws aside so they don’t get lost.
Step 3 Open the top to access the controls area
Pull the lid toward you, lift it slightly, and push it backward to unhook the top from the safety hooks.
Pivot the washer top upward to open the console area.
Step 4 Find the service manual and enter diagnostics
Reach into the front of the washer near the top and pull out the service manual.
Turn the washer on and press any sequence of three buttons three times in a row to enter error code mode.
Step 6 Secure the lid and support the top
Use masking tape to secure the lid to the washer top.
Lift the top fully and lean it gently against the wall for support.
Step 7 Release the interface clips
Use a flathead screwdriver to depress the spring clip on the right side of the interface.
Depress the spring clip on the left side of the interface.
Step 8 Remove the rear plate and swing the interface out
Use a 1/4" nut driver to remove the approximately eight screws holding the rear metal plate behind the interface.
Roll the interface forward to expose the interface board and its wiring.
Step 9 Disconnect the interface wiring
Disconnect the wire harness that connects the interface to the control board.
Disconnect the additional connector on the interface to give yourself more room to work.
Step 10 Inspect the interface board
Inspect the interface board for obvious damage, such as a scorch mark.
Inspect all contact areas to confirm no other contacts are damaged.
Use a 1/4" nut driver to remove the four or five small screws and lift off the cover, if your board has a cover that blocks access for cleaning.
If damage is in a tight spot, remove the pieces on the small speaker box to improve access.
Step 11 Clean the electrical contacts
Use an alcohol prep wipe to wipe down the contact areas on the interface board.
Use a cotton swab to reach small contact points if needed.
Step 12 Reinstall the interface and test
Reinstall any covers you removed from the interface and tighten their screws.
Reconnect the interface to the control board and make sure all other wires are secure.
Plug the washer in, wait about 30 seconds, and test for normal power and operation.
Step 13 Apply conformal coating for protection
Open the conformal coating bottle and use the included brush to coat the exposed electrical PCB areas liberally.
Brush coating onto any electrical connections exposed through or around the plastic.
Let the coating dry for about 15 minutes before reinstalling the board.
Step 14 Reassemble the washer
Snap the interface back into place.
Reinstall the rear metal plate and its screws.
If cleaning the interface board restores normal operation, protect it from repeat moisture damage by applying the conformal coating and making sure every connector is fully seated during reassembly. If the washer still will not start and the interface will not communicate properly, replacing the interface board is the next likely repair. Repair didn't go as planned? Ask our Answers community for help.
