Whip Stitch on a Tear
    1. Whip Stitch on a Tear, Into to the whip stitch: step 1, image 1 of 3 Whip Stitch on a Tear, Into to the whip stitch: step 1, image 2 of 3 Whip Stitch on a Tear, Into to the whip stitch: step 1, image 3 of 3
      • Structure - The whip stitch is a simple looping stitch that creates a spiral of thread.
      • Repair Use - This stretch stitch is highly versatile and can be used to seal a tear, bind a raw fabric edge, or attach a patch.
      • When placed close together, whip stitches can also reinforce an opening to create a buttonhole or a decorative eyelet.
      Ask FixBot
    2. Whip Stitch on a Tear, Assess the damage: step 2, image 1 of 3 Whip Stitch on a Tear, Assess the damage: step 2, image 2 of 3 Whip Stitch on a Tear, Assess the damage: step 2, image 3 of 3
      • Locate the damaged area and trim away any loose or hanging threads.
      • In this tutorial, the whip stitch will be used to seal a short, straight tear with minimal fraying and fabric loss.
      • If the damage is more extensive, a variation of this technique can be used to attach a patch over the damaged area. See Whip Stitch on a Patch or Blanket Stitch on a Patch.
      Ask FixBot
      • Cut a length of thread approximately 24 inches (~61 cm) long.
      • The pictured repair uses contrast thread for visibility, but matching thread will make this repair more invisible.
      • Thread the needle and adjust the thread so there are equal lengths of thread on each side of the needle.
      • Tie an overhand knot with both ends to create a doubled length of thread.
      • See Needles and Thread for more details.
      Ask FixBot
    3. Whip Stitch on a Tear, Start the stitch: step 4, image 1 of 2 Whip Stitch on a Tear, Start the stitch: step 4, image 2 of 2
      • Insert the needle up from the backside of the fabric, about 1/8 inch (~3 mm) diagonally away from the end of the tear. Pull tight so the knot is flush on the backside.
      • Pierce down into the fabric 1/4 inch (~6 mm) away from the first stitch, on the opposite side of the tear, then bring the needle back up right next to the first stitch, about 1/8 inch (~3 mm) away. Pull through.
      • The first stitch will be in the undamaged fabric before the tear. This will serve as an anchor that stabilizes the rest of the stitch line.
      Ask FixBot
    4. Whip Stitch on a Tear, Continue the stitch: step 5, image 1 of 1
      • Repeat the process from the previous step to continue stitching in a spiral pattern, passing the needle from one side of the tear to the other.
      • The stitches should be no more than 1/8 inch (~3 mm) apart for a secure and even repair.
      • Maintain consistent tension and spacing for a neat appearance.
      • Thread that's too tight will pucker the fabric and thread that's too loose won't effectively seal the tear.
      Ask FixBot
    5. Whip Stitch on a Tear, Finish the stitch: step 6, image 1 of 3 Whip Stitch on a Tear, Finish the stitch: step 6, image 2 of 3 Whip Stitch on a Tear, Finish the stitch: step 6, image 3 of 3
      • Continue whip stitching until you get to the opposite side of the tear.
      • Make a final stitch beyond the end of the tear to secure the stitching, just as it was anchored at the beginning of the tear.
      • Pass the needle through to the backside of the fabric.
      • Make a secure knot on the backside of the fabric using one of the techniques from Knot Thread to the Fabric (2 Ways) and trim the extra thread.
      Ask FixBot
    6. Whip Stitch on a Tear, Quality check: step 7, image 1 of 3 Whip Stitch on a Tear, Quality check: step 7, image 2 of 3 Whip Stitch on a Tear, Quality check: step 7, image 3 of 3
      • Check that the tear is effectively sealed and that the stitching has even spacing and appropriate tension.
      • Trim any loose threads.
      Ask FixBot
Finish Line
3 other people completed this guide.
Sabrina K
806 Reputation
3 Guides authored
Patagonia Member of Patagonia
Community
9 Members
383 Guides authored
0 Guide Comments
Past 24 Hours: 17
Past 7 Days: 130
Past 30 Days: 488
All Time: 2,829
