Up to 20% off select tools
Wheelbarrow Handle Replacement
Views: 6.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
22
Past 30 Days:
133
All Time:
6,380
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 40 minutes - 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
Wheelbarrow handles rot or even break after years of use and weathering. Simply replace the handle of your wheelbarrow for a renewal of your wheeled garden utility.
This guide will go over the process for selecting your handle, disassembling your wheelbarrow, drilling holes in the new handle, and reassembling your wheelbarrow. The specific wheelbarrow used was a True Temper Dual Wheel Wheelbarrow.
    1. Wheelbarrow Handle Replacement, Handle: step 1, image 1 of 3 Wheelbarrow Handle Replacement, Handle: step 1, image 2 of 3 Wheelbarrow Handle Replacement, Handle: step 1, image 3 of 3
      • Remove the screws from beneath the handles to detach them from the wheelbarrow.
      Ask FixBot
    2. Wheelbarrow Handle Replacement: step 2, image 1 of 3 Wheelbarrow Handle Replacement: step 2, image 2 of 3 Wheelbarrow Handle Replacement: step 2, image 3 of 3
      • Measure and record the following dimensions of the wheelbarrow handle:
      • Length,
      • Width,
      • and Thickness.
      • Use the recorded dimensions of the wheelbarrow hand to purchase a new handle.
      Ask FixBot
    3. Wheelbarrow Handle Replacement: step 3, image 1 of 1
      • Align the ends and sides of the old handle with new handle.
      • Use a bolt from the wheelbarrow and a hammer to mark the new handle with the location of the old handle's holes.
      Ask FixBot
    4. Wheelbarrow Handle Replacement: step 4, image 1 of 1
      • Use the marked locations from Step 4 to drill holes with the 5/16 drill bit.
      Ask FixBot
    5. Wheelbarrow Handle Replacement: step 5, image 1 of 3 Wheelbarrow Handle Replacement: step 5, image 2 of 3 Wheelbarrow Handle Replacement: step 5, image 3 of 3
      • Turn the wheelbarrow shell on its side and put the bolts though the shell and handle.
      • Attach the legs, axel assembly, and wheel guard to the shell and handles.
      • Keep all screws loose until all pieces are in place.
      • Tighten all screws.
      • If you are unsure how to reassemble your wheelbarrow, there could be assembly instructions for your wheelbarrow on the company website from which you purchased your wheelbarrow.
      Ask FixBot
To drill the holes, you could use a drill press instead of a cordless drill to ensure the perpendicularity of the holes being drilled.
Author
with
Alan Farias Andonian
148 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 133
All Time: 6,380
