Wexford CT-166TF Plastic Casing Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
93
All Time:
820
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you how to remove the plastic casing so that it can be replaced.
Tools
    1. Wexford CT-166TF Plastic Casing  Replacement, Settings Knob: step 1, image 1 of 1
      • Locate the knob at the top of the fan.
      Ask FixBot
    2. Wexford CT-166TF Plastic Casing  Replacement: step 2, image 1 of 1
      • Remove the knob by gripping it and pulling straight up. Use a spudger if it is difficult to grip.
      • When reassembling, be sure to align the bottom of the new knob and the turning mechanism in the fan before pushing down.
      Ask FixBot
    1. Wexford CT-166TF Plastic Casing  Replacement, Plastic Casing: step 3, image 1 of 1
      • Using the plastic opening tool, turn the device over and remove the black plastic covers over the four screw holes.
      Ask FixBot
    2. Wexford CT-166TF Plastic Casing  Replacement: step 4, image 1 of 2 Wexford CT-166TF Plastic Casing  Replacement: step 4, image 2 of 2
      • Remove the four screws underneath the plastic covers.
      Ask FixBot
    3. Wexford CT-166TF Plastic Casing  Replacement: step 5, image 1 of 2 Wexford CT-166TF Plastic Casing  Replacement: step 5, image 2 of 2
      • Remove 5 smaller screws visible through small holes between the base and the casing.
      Ask FixBot
    4. Wexford CT-166TF Plastic Casing  Replacement: step 6, image 1 of 2 Wexford CT-166TF Plastic Casing  Replacement: step 6, image 2 of 2
      • Remove four screws on the back, two near the top and two near the bottom.
      Ask FixBot
    5. Wexford CT-166TF Plastic Casing  Replacement: step 7, image 1 of 1
      • Pull off the back casing.
      Ask FixBot
    6. Wexford CT-166TF Plastic Casing  Replacement: step 8, image 1 of 2 Wexford CT-166TF Plastic Casing  Replacement: step 8, image 2 of 2
      • Remove the 2 screws that attach the front part of the casing to the motor.
      Ask FixBot
    7. Wexford CT-166TF Plastic Casing  Replacement: step 9, image 1 of 2 Wexford CT-166TF Plastic Casing  Replacement: step 9, image 2 of 2
      • Remove the two middle screws attaching the black plastic cover to the front .
      Ask FixBot
    8. Wexford CT-166TF Plastic Casing  Replacement: step 10, image 1 of 1
      • Remove the two screws attached to the white bar near the red light on the top of the front casing.
      Ask FixBot
    9. Wexford CT-166TF Plastic Casing  Replacement: step 11, image 1 of 1
      • Remove the two screws keeping the button attached to the top of the casing.
      Ask FixBot
2 other people completed this guide.
Cameron Mattson
125 Reputation
1 Guide authored
UW Tacoma, Team S3-G4, Liner Spring 2017 Member of UW Tacoma, Team S3-G4, Liner Spring 2017
UWT-LINER-S17S3G4
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 93
All Time: 820
