Westcott iPoint Evolution Outer Casing Replacement
    1. Westcott iPoint Evolution Outer Casing Replacement, Outer Casing: step 1, image 1 of 1
      • Step 1: Start with the back of the pencil sharpener facing you.
      • This allows you to locate the power source.
      Ask FixBot
    2. Westcott iPoint Evolution Outer Casing Replacement: step 2, image 1 of 1
      • Step 2: Grab the end of the plug located at the bottom of the sharpener and pull it out gently.
      Ask FixBot
    3. Westcott iPoint Evolution Outer Casing Replacement: step 3, image 1 of 2 Westcott iPoint Evolution Outer Casing Replacement: step 3, image 2 of 2
      • There are three parts of the sharpener.
      • Step 3: Grab the very top of the sharpener, twist it to the right and lift it up to remove it.
      Ask FixBot
    4. Westcott iPoint Evolution Outer Casing Replacement: step 4, image 1 of 3 Westcott iPoint Evolution Outer Casing Replacement: step 4, image 2 of 3 Westcott iPoint Evolution Outer Casing Replacement: step 4, image 3 of 3
      • Step 4: Grab the center of the sharpener and lift it up to remove the piece.
      Ask FixBot
    5. Westcott iPoint Evolution Outer Casing Replacement: step 5, image 1 of 3 Westcott iPoint Evolution Outer Casing Replacement: step 5, image 2 of 3 Westcott iPoint Evolution Outer Casing Replacement: step 5, image 3 of 3
      • Step 5: Remove the small ring that is around the sharpener.
      • This piece is below the center of the sharpener that you just removed.
      Ask FixBot
    6. Westcott iPoint Evolution Outer Casing Replacement: step 6, image 1 of 1
      • Step 6: Flip the pencil sharpener upside down.
      • Locate the four screws on the bottom of the sharpener.
      Ask FixBot
    7. Westcott iPoint Evolution Outer Casing Replacement: step 7, image 1 of 1
      • Step 7: Take a screwdriver and unscrew all of the screws on the bottom.
      Ask FixBot
    8. Westcott iPoint Evolution Outer Casing Replacement: step 8, image 1 of 1
      • Step 8: After all the screws are removed gently take off the bottom of the sharpener.
      Ask FixBot
    9. Westcott iPoint Evolution Outer Casing Replacement: step 9, image 1 of 1
      • Step 9: Carefully lift the lid off of the sharpener.
      Ask FixBot
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 70
All Time: 13,219
