Waterlogged Samsung Galaxy Grand Prime
    1. Waterlogged Samsung Galaxy Grand Prime, Waterlogged Samsung Galaxy Grand Prime: step 1, image 1 of 2 Waterlogged Samsung Galaxy Grand Prime, Waterlogged Samsung Galaxy Grand Prime: step 1, image 2 of 2
      • Power off your waterlogged Samsung Galaxy Grand Prime to prevent potential damage to the running circuitry
      • Place the phone with its screen facing the work surface
      Ask FixBot
    2. Waterlogged Samsung Galaxy Grand Prime: step 2, image 1 of 3 Waterlogged Samsung Galaxy Grand Prime: step 2, image 2 of 3 Waterlogged Samsung Galaxy Grand Prime: step 2, image 3 of 3
      • Position the primary back panel towards you
      • Detach the primary back panel to expose the battery in the secondary back panel
      Ask FixBot
    3. Waterlogged Samsung Galaxy Grand Prime: step 3, image 1 of 3 Waterlogged Samsung Galaxy Grand Prime: step 3, image 2 of 3 Waterlogged Samsung Galaxy Grand Prime: step 3, image 3 of 3
      • Using a 1.5x25 millimeter Phillips head screwdriver, remove the nine 4mm screws to gain access to the inner circuitry.
      • Put the screws to the side in order to avoid misplacement
      Ask FixBot
    4. Waterlogged Samsung Galaxy Grand Prime: step 4, image 1 of 3 Waterlogged Samsung Galaxy Grand Prime: step 4, image 2 of 3 Waterlogged Samsung Galaxy Grand Prime: step 4, image 3 of 3
      • Remove the battery to prevent damage during the process
      • Gently peel up the battery and set it aside
      Ask FixBot
    5. Waterlogged Samsung Galaxy Grand Prime: step 5, image 1 of 3 Waterlogged Samsung Galaxy Grand Prime: step 5, image 2 of 3 Waterlogged Samsung Galaxy Grand Prime: step 5, image 3 of 3
      • Carefully peel away the screen display from the secondary back panel
      • Use a hair dryer if needed to soften adhesive
      Ask FixBot
    6. Waterlogged Samsung Galaxy Grand Prime: step 6, image 1 of 3 Waterlogged Samsung Galaxy Grand Prime: step 6, image 2 of 3 Waterlogged Samsung Galaxy Grand Prime: step 6, image 3 of 3
      • Address areas of concern in the main frame with a small towel or cotton swab
      • Submerging both parts in a container of desiccants like silica gel for a period of time can also be another option
      Ask FixBot
    7. Waterlogged Samsung Galaxy Grand Prime: step 7, image 1 of 3 Waterlogged Samsung Galaxy Grand Prime: step 7, image 2 of 3 Waterlogged Samsung Galaxy Grand Prime: step 7, image 3 of 3
      • Make sure that there is no remaining liquid
      • Reassemble the phone, starting with the screen and secondary back panel
      • Press in on every side until the frame clicks into place
      Ask FixBot
    8. Waterlogged Samsung Galaxy Grand Prime: step 8, image 1 of 3 Waterlogged Samsung Galaxy Grand Prime: step 8, image 2 of 3 Waterlogged Samsung Galaxy Grand Prime: step 8, image 3 of 3
      • Retrieve the battery set aside in step 4
      • Orient it correctly so the phone can properly boot up later
      • Carefully place the battery back into its slot
      Ask FixBot
    9. Waterlogged Samsung Galaxy Grand Prime: step 9, image 1 of 3 Waterlogged Samsung Galaxy Grand Prime: step 9, image 2 of 3 Waterlogged Samsung Galaxy Grand Prime: step 9, image 3 of 3
      • Retrieve all of the 4mm screws you put aside in Step 3
      • Using the 1.5x25 millimeter Phillips head screwdriver, tighten all 9 of the 4mm screws
      • Confirm that each screw is sufficiently tightened to ensure stability and proper function
      Ask FixBot
    10. Waterlogged Samsung Galaxy Grand Prime: step 10, image 1 of 3 Waterlogged Samsung Galaxy Grand Prime: step 10, image 2 of 3 Waterlogged Samsung Galaxy Grand Prime: step 10, image 3 of 3
      • Bring back the primary back panel from step 2
      • Align the primary back panel with the secondary back panel, ensuring the Samsung logo is facing outward
      • Click the panels together and work your way around until all sides are securely attached
      Ask FixBot
    11. Waterlogged Samsung Galaxy Grand Prime: step 11, image 1 of 2 Waterlogged Samsung Galaxy Grand Prime: step 11, image 2 of 2
      • Charge the phone with a USB Micro-B cable so it has an initial charge when opening it back up
      • When all steps are performed correctly, the phone should power up and work as intended
      Ask FixBot
Finish Line
4 other people completed this guide.
Johny Vu
265 Reputation
1 Guide authored
CSU Los Angeles, Team 9-7, Ribeiro Fall 2023 Member of CSU Los Angeles, Team 9-7, Ribeiro Fall 2023
CSULA-RIBEIRO-F23S9G7
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 59
All Time: 847
