Water Dancing Speakers Refill
    1. Water Dancing Speakers Refill, Water plug & water: step 1, image 1 of 2 Water Dancing Speakers Refill, Water plug & water: step 1, image 2 of 2
      • You will need to have a clean work space, water dancing speakers, super glue, mineral water, and Phillips screw driver ready.
      • Unplug the USB cable powering your speakers before you continue.
      Ask FixBot
    2. Water Dancing Speakers Refill: step 2, image 1 of 1
      • Using the phillips screw driver remove the 4 screws seen on the back of speakers.
      Ask FixBot
    3. Water Dancing Speakers Refill: step 3, image 1 of 1
      • Once the four screws are taken out you will need to slide the bottom piece from the water canister.
      • When the two are separated set the water canister bottom facing up.
      Ask FixBot
    4. Water Dancing Speakers Refill: step 4, image 1 of 2 Water Dancing Speakers Refill: step 4, image 2 of 2
      • On the bottom of the water canister you will see a hole where the water was inserted. There will be a black plug covering the hole.
      • Using your screw driver you can pry the plug out.
      • Once the plug is taken out you can refill the speakers. Only refill the speakers with one inch of water.
      Ask FixBot
    5. Water Dancing Speakers Refill: step 5, image 1 of 1
      • After the water is filled to approximately one inch. Super glue the hole shut and let dry.
      Ask FixBot
    6. Water Dancing Speakers Refill: step 6, image 1 of 1
      • When the glue is dry slide speaker back on to water canister.
      • Once they are put together place back panel on and insert the four screws.
      • repeat steps 2 through 6 on second speaker.
      Ask FixBot
Your water dancing speakers are now ready for use. Thank you for using this guide.
48 other people completed this guide.
Andrew
1,387 Reputation
2 Guides authored
36 Guide Comments
the pump is defective how to replace
anpicard@videotron.ca
andrepicard2012 - Reply Share
I couldnt get plug out either so I drilled a hole in back and filled it with mineral water and sealed it with a small strip of scotch tape and duct tape on top of that in case I had to get back in. It works, but now it looks different. Sometimes the water clings to the inside and it looks a little foggy. Is it mineral water, or mineral oil? If it leaks again I'll prob try the oil.
Lacepage - Reply Share
The original liquid has a lower surface tension than water. I used odorless mineral spirits.
If the pump is noisy, try a drop of oil in the motor.
aeromojito - Reply Share
My speakers keep spraying even though their is no music playing, is that a good thing?
Andrew - Reply Share
That means that the speakers are broken. You might need to replace it. If not, then its a probelm with the board, which I have no idea how to fix.
Skittlekingthefirst - Reply Share
Past 24 Hours: 7
Past 7 Days: 64
Past 30 Days: 242
All Time: 173,766
